0 Replies Latest reply on May 9, 2008 5:53 PM by (Jono_Spiro)
    [svn] 1660: ignore: setting autoprops on everything in the trunk -- well, almost everything, we'll cover the last few filetypes later...
    Level 1
      Revision: 1660
      Author: jspiro@adobe.com
      Date: 2008-05-09 18:53:47 -0700 (Fri, 09 May 2008)
      Log Message:
      Reviewer: Gordon reviewed this by yelling "Cool" from across the room.
      Modified Paths:
      flex/sdk/trunk/collateral/ja_JP/readme-open_ja.htm
      flex/sdk/trunk/development/eclipse/java/formatter.xml
      flex/sdk/trunk/frameworks/projects/airframework/bundles/da_DK/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/de_DE/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/es_ES/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/fi_FI/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/fr_FR/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/it_IT/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/ko_KR/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/nb_NO/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/nl_NL/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/pt_BR/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/sv_SE/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/zh_CN/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/airframework/bundles/zh_TW/aircontrols.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/validators.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/SharedResources.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/collections.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/containers.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/controls.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/core.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/effects.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/formatters.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/logging.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/skins.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/states.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/styles.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/utils.properties
      flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/validators.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/da_DK/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/da_DK/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/de_DE/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/de_DE/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/es_ES/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/es_ES/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/fi_FI/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/fi_FI/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/fr_FR/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/fr_FR/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/it_IT/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/it_IT/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/ko_KR/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/ko_KR/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/nb_NO/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/nb_NO/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/nl_NL/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/nl_NL/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/pt_BR/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/pt_BR/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/sv_SE/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/sv_SE/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/zh_CN/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/zh_CN/rpc.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/zh_TW/messaging.properties
      flex/sdk/trunk/frameworks/projects/rpc/bundles/zh_TW/rpc.properties
      flex/sdk/trunk/lib/xalan-LICENSE.txt
      flex/sdk/trunk/modules/antTasks/FlexAntTasks-license.txt
      flex/sdk/trunk/modules/antTasks/README.txt
      flex/sdk/trunk/modules/antTasks/bin/optleft.sh
      flex/sdk/trunk/modules/compiler/FlexCompilerShell-license.txt
      flex/sdk/trunk/modules/compiler/README.txt
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerBenchmarkHelper.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/EmbedClass.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/StyleProperty.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableProperty.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/WatcherSetupUtil.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedProperty.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/FontFaceRules.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleLibrary.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleModule.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/SkinClass.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDef.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/InterfaceDef.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/PerformanceData.java
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concrete/appleScriptCloseCa minoWindow.txt
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concrete/appleScriptCloseSa fariWindow.txt
      flex/sdk/trunk/modules/debugger/src/java/flash/tools/debugger/concrete/appleScriptGetDefa ultBrowserName.txt
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/fdbhelp_en.txt
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/fdbhelp_ja.txt
      flex/sdk/trunk/mustella/mini_run.sh
      flex/sdk/trunk/samples/explorer/build.bat
      flex/sdk/trunk/samples/explorer/build.sh
      flex/sdk/trunk/samples/explorer/charts/build-charts.bat
      flex/sdk/trunk/samples/explorer/charts/build-charts.sh
      flex/sdk/trunk/samples/ja_JP/explorer/build.bat
      flex/sdk/trunk/samples/ja_JP/explorer/build.sh
      flex/sdk/trunk/templates/html-templates/metadata/readme.txt
      flex/sdk/trunk/tools/dependencychecker/.project
      flex/sdk/trunk/tools/dependencychecker/exceptionsListExample.txt
      flex/sdk/trunk/tools/dependencychecker/frameworkSwcExceptionsList.txt
      flex/sdk/trunk/tools/diffpack/.project
      Property Changed:
      flex/sdk/trunk/bin/aasdoc.bat
      flex/sdk/trunk/bin/acompc.bat
      flex/sdk/trunk/bin/amxmlc.bat
      flex/sdk/trunk/collateral/en_US/license-mpl.htm
      flex/sdk/trunk/development/eclipse/flex/framework/.project
      flex/sdk/trunk/development/eclipse/flex/rpc/.project
      flex/sdk/trunk/development/eclipse/java/flex-asc/.project
      flex/sdk/trunk/development/eclipse/java/flex-compiler/.project
      flex/sdk/trunk/development/eclipse/java/flex-debugger/.project
      flex/sdk/trunk/development/eclipse/java/flex-flextasks/.project
      flex/sdk/trunk/development/eclipse/java/flex-jars/.project
      flex/sdk/trunk/development/eclipse/java/flex-swfutils/.project
      flex/sdk/trunk/development/eclipse/readme.txt
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/AbstractGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/package.html
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/package.html
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/zip/ant-LICENSE.txt
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/zip/ant-NOTICE.txt
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/package.html
