0 Replies Latest reply on May 13, 2008 7:24 AM by (Jim_Murphy)
    [svn] 1679: merge trunk asc changes to 3.0.x
    Level 1
      Revision: 1679
      Author: jimurphy@adobe.com
      Date: 2008-05-13 08:24:12 -0700 (Tue, 13 May 2008)
      Log Message:
      block this change from being merged back to trunk
      Modified Paths:
      flex/sdk/branches/3.0.x/modules/asc/bin/jvm.config
      flex/sdk/branches/3.0.x/modules/asc/build/java/build.xml
      flex/sdk/branches/3.0.x/modules/asc/build/util/errorConfig.xml
      flex/sdk/branches/3.0.x/modules/asc/build/util/lintConfig.xml
      flex/sdk/branches/3.0.x/modules/asc/src/java/adobe/abc/GlobalOptimizer.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/AbcParser.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/ConstantPool.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/Decoder.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/Encoder.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/OpcodeVisitor.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/Opcodes.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/Optimizer.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/Printer.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/Scanner.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/abc/Visitor.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/BatchCompiler.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/Compiler.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/CompilerPlug.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/ErrorConstants.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/LintEvaluator.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/Main.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/ScriptCompiler.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/Shell.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/SwfMaker.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/WarningConstants.ja va
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/avmplus/ActionBlock Constants.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/avmplus/ActionBlock Emitter.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/avmplus/ByteCodeFac tory.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/avmplus/Features.ja va
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/avmplus/GlobalBuild er.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/embedding/avmplus/RuntimeCons tants.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/BinaryExpressionNode.j ava
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/EmptyStatementNode.jav a
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/Evaluator.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/IncrementNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/InputBuffer.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/LiteralNumberNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/MetaDataEvaluator.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/Node.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/NodeFactory.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/NodePrinter.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/PackageIdentifiersNode .java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/ParameterListNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/Parser.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/Scanner.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/SelectorNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/StatementListNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/Tokens.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/TypedIdentifierNode.ja va
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/UnaryExpressionNode.ja va
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/CodeGenerator.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/ConfigurationEvalua tor.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/ConstantEvaluator.j ava
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/Emitter.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/FlowAnalyzer.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/ObjectValue.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/ObjectValueWrapper. java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/QName.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/ReferenceValue.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/TypeInfo.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/TypeValue.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/Context.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/ContextStatics.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/Multinames.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/Names.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/NamespacesTable.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/graph/Algorithms.java
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/CN/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/CN/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/DE/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/DE/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/EN/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/ES/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/ES/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/FR/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/FR/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/IT/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/IT/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/JP/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/JP/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/KR/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/KR/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/TW/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/TW/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/AccPropWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ActivateTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/AddListenerWarn2.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/AddedTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/AsBroadcasterClassWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/BitmapDataWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ButtonMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMactive.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMbutton.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMcall.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMcapabilities.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMcolor.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMloadVars.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMmovieClipLoader.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMmovieclip.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMnetStream.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMobject.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMselection.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMsharedObject.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMsound.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMstage.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMstylesheet.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMsubstring.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMsystem.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMtextField.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMtextFormat.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMtimeout.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMvideo.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMxmlSocketTest.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CMxmldoc.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CameraEventsWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CameraGetWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CancelTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ChangeTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CharCodeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ChrWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ClearIntervalWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CloseTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ColorMethodsWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/CompleteTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ConnectTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ContainerMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ContextMenuCopyWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ContextMenuEventsWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ContextMenuForward_BackWar n.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ContextMenuItemCopyWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ContextMenuItemEventsWarn. err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ContextMenuMethodsWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DateWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DeactivateTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DeleteKeyWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DiffDataTypesWithNullUndef inedWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DiffDataTypesWithNullUndef inedWarn_warnings.txt
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectAlphaWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectHeightWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectMaskWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectMouseXWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectMouseYWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectNameWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectParentWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectRotationWarn. err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectScaleXWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectScaleYWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectVisibleWarn.e rr
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectWidthWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectXWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DisplayObjectYWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/DuplicateMovieClipWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/EnterFrameTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/FileReferenceEventsWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/FileReferenceListWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/FileReferenceMethodsWarn.e rr
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/FocusInTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/FocusOutTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/GetCodeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/GetPropertyWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/GlobalFunctionsWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/GotoAndPlayWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/GotoAndStopWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/IMEMethodsWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/Id3TypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ImageFilterMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ImageLoaderInfoMethWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ImageMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ImageSpriteMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ImeEventMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/InitTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/IsDownWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/IsToggledWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/KeyFocusChangeTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/KeyMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/KeyPropWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/KeyboardClassConstWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/KeyboardClassMethodsWarn.e rr
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/LengthWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/LineMetricsMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ListPropWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/LoadMovieNumWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/LoadMovieWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/LoadVariablesWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/LoadVarsMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/LocalConnectionWarnings.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MbChrWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MbLengthWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MbOrdWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MbSubStringWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MenuEventMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MicrophoneEventsMethodsWar n.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MouseClassEventsMethodsWar n.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MouseFocusChangeTypeWarn.e rr
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MouseLeaveTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MovieClipEvents.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MovieclipLoaderClassWarn.e rr
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/MovieclipUrlWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/NetConnIsConnectedPropWarn .err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/NextFrameWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/NumPadWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/OpenTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/OrdWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/PGDNWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/PGUPWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/PlayWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/PrintAsBitmapNumWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/PrintAsBitmapWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/PrintNumWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ProtoPropWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/RandomWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/RemoveMovieclipWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/RemovedTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/RenderTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ResizeTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ScalingGridPropWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ScrollTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/SelectTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/SetIntervalWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/SetPropertyWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/SocketIsConnectedPropWarn. err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/SoundCompleteTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/StageQualityWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/StartDragWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/StopAllSoundsWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/StopDragWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/StopWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/SubStringWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/SystemCapabilitiesMethWarn .err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/SystemCapabilitiesPropWarn .err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/TabChildrenChangeTypeWarn. err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/TabEnabledChangeTypeWarn.e rr
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/TabIndexChangeTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/TextExtentsMethWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/TextExtentsPropWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/TextFieldBottomScrollPropW arn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/TextFieldScrollPropWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/TextSnapshotClassWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/TextSnapshotMethodsWarn.er r
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/ToggleHighQualityWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/URLStreamIsConnectedPropWa rn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/UnloadMovieNumWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/UnloadTypeWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/UnsupportedAS2FunctionWarn .err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/UnsupportedAS2PropertyWarn .err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/VersionPropWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/as3/Warnings/XYZQualityWarn.err
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/runtests.py
      flex/sdk/branches/3.0.x/modules/asc/test/compiler/testconfig.txt
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/build.properties
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/build.xml
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/IllegalOverrideClass_Fail.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/IllegalOverrideInterfaceGetter_Fa il.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/IllegalOverrideInterfaceMethod_Fa il.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/IllegalOverrideInterfaceSetter_Fa il.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/b132189.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/b135181.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/b153336.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/b154869.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/b155288.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/b161702.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/b191112.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/b191112.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/class_ctor.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/class_ctor.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/exceptions.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/tests/b155288.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/tests/b191112.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/tests/class_ctor.as
      Added Paths:
      flex/sdk/branches/3.0.x/modules/asc/README.txt
      flex/sdk/branches/3.0.x/modules/asc/abc/
      flex/sdk/branches/3.0.x/modules/asc/abc/builtin.abc
      flex/sdk/branches/3.0.x/modules/asc/abc/playerglobal.abc
      flex/sdk/branches/3.0.x/modules/asc/abc/toplevel.abc
      flex/sdk/branches/3.0.x/modules/asc/bin/linux/
      flex/sdk/branches/3.0.x/modules/asc/bin/linux/avmplus_s
      flex/sdk/branches/3.0.x/modules/asc/bin/mac/
      flex/sdk/branches/3.0.x/modules/asc/bin/mac/shell_s
      flex/sdk/branches/3.0.x/modules/asc/bin/mac/shell_s_ppc
      flex/sdk/branches/3.0.x/modules/asc/bin/windows/
      flex/sdk/branches/3.0.x/modules/asc/bin/windows/avmplus_s.exe
      flex/sdk/branches/3.0.x/modules/asc/build/java/build.properties
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/ApplyTypeExprNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/TypeIdentifierNode.jav a
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/UseNumericNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/UsePragmaNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/UsePrecisionNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/parser/UseRoundingNode.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/semantics/ParameterizedName.j ava
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/Decimal128.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/Decimal128Context.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/DecimalNumberConstant.ja va
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/DenselyPackedDecimal.jav a
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/DoubleNumberConstant.jav a
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/IntNumberConstant.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/NumberConstant.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/NumberUsage.java
      flex/sdk/branches/3.0.x/modules/asc/src/java/macromedia/asc/util/UintNumberConstant.java
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/CS/
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/CS/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/CS/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/NL/
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/NL/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/NL/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/PL/
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/PL/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/PL/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/PT/
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/PT/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/PT/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/RU/
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/RU/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/RU/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/SV/
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/SV/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/SV/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/TR/
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/TR/ErrorConstants.xml
      flex/sdk/branches/3.0.x/modules/asc/src/localized_strings/TR/Lint_Warnings.xml
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/README.txt
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/unused/
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/unused/decimal1.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/unused/es4-initlist.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/unused/es4-initlistnosuper.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/unused/es4-propiniterror.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/unused/es4-thisInInit.as
      Removed Paths:
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/es4-initlist.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/es4-initlist.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/es4-initlistnosuper.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/es4-initlistnosuper.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/es4-propiniterror.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/es4-propiniterror.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/es4-thisInInit.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/regress/es4-thisInInit.log
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/tests/es4-initlist.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/tests/es4-initlistnosuper.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/tests/es4-propiniterror.as
      flex/sdk/branches/3.0.x/modules/asc/test/sanity/tests/es4-thisInInit.as
