0 Replies Latest reply on Jun 5, 2008 6:18 AM by (Paul_Reilly)
    [svn] 1965: * Made AST generation the default.
    Level 1
      Revision: 1965
      Author: preilly@adobe.com
      Date: 2008-06-05 07:18:47 -0700 (Thu, 05 Jun 2008)
      Log Message:
      * Made AST generation the default. To turn it off set
      -generate-abstract-syntax-tree to false.
      * Fixed two small issues found by the mxunit and mxmlcunit tests.
      tests Passed: checkintests, mxunit and mxmlcunit
      Needs QA: YES
      Needs DOC: NO
      Bug fixes:
      API Change: NO
      Reviewer: pfarland
      Code-level description of changes:
      as3/OffsetInputBuffer.java
      Modified constructor to set "curr_line_offset", because if the
      first token is xml, "curr_line_offset" will not have been
      initialized using "pos".
      common/CompilerConfiguration.java
      Changed generateAbstractSyntaxTree to true.
      mxml/rep/BindingExpression.java
      Modified generateNamespaceDeclarations() to intern the generated
      namespace, because it is assumed to be interned by ASC. The
      assert in IdentifierNode caught this.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/OffsetInputBuffer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
