0 Replies Latest reply on Jun 5, 2008 7:12 AM by (Paul_Reilly)
    [svn] 1967: * Fixed issue where -keep-generated-actionscript would not work
      Revision: 1967
      Author: preilly@adobe.com
      Date: 2008-06-05 08:12:21 -0700 (Thu, 05 Jun 2008)
      Log Message:
      properly when -generate-abstract-syntax-tree was enabled, which is
      now the default.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: clucier
      Code-level description of changes:
      CompilerConfiguration.java
      Modified setKeepGeneratedActionScript() to force AST generation
      off when the value is true.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
