0 Replies Latest reply on Jun 11, 2008 6:18 AM by (Paul_Reilly)
    [svn] 2040: Fixed some bugs and inconsistencies found by turning on AST generation
      Revision: 2040
      Author: preilly@adobe.com
      Date: 2008-06-11 07:18:14 -0700 (Wed, 11 Jun 2008)
      Log Message:
      by default.
      tests Passed: checkintests, mxmlcunit ConditionalCompilation, mxunit E4XDataBinding
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-15751, SDK-15752
      API Change: NO
      Reviewer: clucier
      Code-level description of changes:
      swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
      Added dump().
      asc/src/java/macromedia/asc/parser/Parser.java
      Made config_namespaces public, so Flex AST generation can
      initialize it. Also added some asserts to catch the situation
      where config_namespaces is not initialized.
      compiler/src/java/flex2/compiler/as3/As3Compiler.java
      Removed some unnecessary fully qualification for
      macromedia.asc.util.Context and flex2.compiler.CompilerContext.
      compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Added new generateConstructor() variant with a generateSuperCall
      param. This allows InterfaceGenerator to be more consistent with
      the equivalent Velocity template.
      Modified generateContext() to take a "defines" param and to
      initialize config_vars with it.
      Modified parse() to initialize config_namespaces and to use
      parseDirectives() instead of parseProgram(). This should remove
      the need to throw away ConfigNamespaceDefinitionNode and
      UseDirectiveNode nodes, plus it should run slightly faster.
      Added parseConfigVars().
      compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension.java
      Added "defines" variable and modified constructor to initialize
      it.
      Modified ArrayElementWatcher's generateWatcher() and
      generateWatcherBottom() to only generate a watcher if child
      watchers will be written. The Velocity template has this
      optimization, but the AST generation equivalent was missing it.
      compiler/src/java/flex2/compiler/as3/binding/ArrayElementWatcher.java
      compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassEvaluator.java
      compiler/src/java/flex2/compiler/as3/binding/Watcher.java
      Renamed getShouldWriteChildren() to shouldWriteChildren() to be
      more consistent with shouldWriteSelf().
      compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      Modified constructor to take a "defines" param and pass it into
      generateContext().
      Modified generateBindingManagementVars() to be more like
      ImplementationGenerator.generateBindingManagementVars() by using
      AbstractSyntaxTreeUtil.generateMxInternalQualifiedIdentifier() and
      AbstractSyntaxTreeUtil.generateVariable().
      compiler/src/java/flex2/compiler/mxml/AbstractGenerator.java
      Added generateMxInternalAttribute() from ImplementationGenerator,
      so InterfaceGenerator can use it, too.
      compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      Added ascConfiguration variable.
      Modified constructor to initialize ascConfiguration and pass it's
      defines into DataBindingExtension.
      compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      Modified generateImplementationAST() to pass the "defines" into
      compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      generateContext().
      Removed generateMxInternalAttribute().
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-15751
      http://bugs.adobe.com/jira/browse/SDK-15752
      Modified Paths:
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/ArrayElementWatcher.j ava
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/Watcher.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/AbstractGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/tools/SyntaxTreeDumper.java
