0 Replies Latest reply on Jun 25, 2008 9:53 AM by (Paul_Reilly)
    [svn] 2234: Fixes for fdbunit tests when AST generation is enabled.
    Level 1
      Revision: 2234
      Author: preilly@adobe.com
      Date: 2008-06-25 10:53:35 -0700 (Wed, 25 Jun 2008)
      Log Message:
      tests Passed: checkintests, fdbunit tests (All, but four, three of
      which were failing before.)
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-15781
      API Change: NO
      Reviewer: pfarland, tierney
      Code-level description of changes:
      asc/src/java/macromedia/asc/parser/InputBuffer.java
      Made line_breaks protected, so subclasses can prepopulate it.
      asc/src/java/macromedia/asc/embedding/avmplus/ActionBlockEmitter.java
      Modified setPosition() to set the linenum to -1 if the position is
      less than 1. This prevents actual line numbers from being reused
      by subsequent synthetic functions.
      compiler/src/java/flex2/compiler/as3/OffsetInputBuffer.java
      Modified constructor to prepopulate line_breaks with the offset.
      compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Modified generateConstructor() to take a "position" arg and to
      apply to the generated FunctionCommondNode.
      Modified generateProgram() to take a "lineNumber" arg and to add
      it to the CodeFragmentsInputBuffer.
      compiler/src/java/flex2/compiler/as3/BytecodeEmitter.java
      Modified DebugSlot() to no longer short circuit for a null
      InputBuffer and when the line number exceeds the InputBuffer
      length. This was a bogus short circuit, because it didn't take
      into consideration #includes. This fixes SDK-15527 in trunk.
      compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension.java
      Updated generateConstructor() call to reflect new signature.
      compiler/src/java/flex2/compiler/as3/CodeFragmentsInputBuffer.java
      Modified "length" to start with 1 to work around ASC's default of
      setting positions to zero when synthetic.
      Modified getLnNum() to first check the positionToLineNumberMap
      before checking codeFragments List.
      Added addLineNumber().
      compiler/src/java/flex2/compiler/mxml/rep/init/EventInitializer.java
      Modified generateDefinitions() to set the position of the
      ReturnStatementNode, so fdb can know the extent of the event
      handler function.
      compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      Modified generateConstructor() to reflect new signature.
      compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Modified constructor to pass the root's line number into
      generateProgram().
      Added generateConstructor() and modified generateClassDefinition()
      to use it.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-15781
      http://bugs.adobe.com/jira/browse/SDK-15527
      Modified Paths:
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/embedding/avmplus/ActionBlockEmitter.j ava
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/InputBuffer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/BytecodeEmitter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/CodeFragmentsInputBuffer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/OffsetInputBuffer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/EventInitializer.ja va
