0 Replies Latest reply on Jan 22, 2009 6:13 PM by KreeK
    compc ant task and external framework
    Level 1
      I'm writing an ant task to compile a couple of libraries into SWCs and then a shell app (that uses the libraries) into a SWF for deployment. If I compile the libraries by hand then run just the 'mxmlc' part of my ant script it compiles fine. However when I try and first compile a library into a SWC with 'compc' it compiles but then the shell app complains that the classes from the library are missing. One thing that may be causing the problem is my library path (through flex builder) has it's framework.swc set to 'Link Type: External' and I'm not sure how to define that with 'compc'. The weird thing is the flex builder compiled and 'compc' compiled SWCs are the same size. Here's my target for 'compc':
