0 Replies Latest reply on Jul 14, 2008 11:13 AM by (Jim_Murphy)
    [svn] 2462: gumbo push to trunk
    Level 1
      Revision: 2462
      Author: jimurphy@adobe.com
      Date: 2008-07-14 12:13:06 -0700 (Mon, 14 Jul 2008)
      Log Message:
      gumbo push to trunk
      Modified Paths:
      flex/sdk/trunk/README.txt
      flex/sdk/trunk/build.properties
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/development/eclipse/flex/framework/.actionScriptProperties
      flex/sdk/trunk/development/eclipse/flex/framework/.flexLibProperties
      flex/sdk/trunk/development/eclipse/flex/framework/.project
      flex/sdk/trunk/development/eclipse/flex/framework/.settings/org.eclipse.core.resources.pr efs
      flex/sdk/trunk/development/eclipse/flex/rpc/.actionScriptProperties
      flex/sdk/trunk/development/eclipse/flex/rpc/.project
      flex/sdk/trunk/development/eclipse/readme.txt
      flex/sdk/trunk/frameworks/air-config.xml
      flex/sdk/trunk/frameworks/build.xml
      flex/sdk/trunk/frameworks/build_framework.xml
      flex/sdk/trunk/frameworks/flex-config.xml
      flex/sdk/trunk/frameworks/libs/player/10/playerglobal.swc
      flex/sdk/trunk/frameworks/mxml-manifest.xml
      flex/sdk/trunk/frameworks/projects/airframework/build.xml
      flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
      flex/sdk/trunk/frameworks/projects/flex/build.xml
      flex/sdk/trunk/frameworks/projects/framework/build.xml
      flex/sdk/trunk/frameworks/projects/framework/manifest.xml
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/CalendarLayout.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateField.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/PopUpButton.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientBase.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/IStroke.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradient.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/LinearGradientStroke.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradient.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/Stroke.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ActivatorSkin.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ButtonBarButtonSkin.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/LinkSeparator.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/PanelSkin.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/TabSkin.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/AddChild.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/RemoveChild.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetEventHandler.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetProperty.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetStyle.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/State.as
      flex/sdk/trunk/frameworks/projects/haloclassic/build.xml
      flex/sdk/trunk/frameworks/projects/rpc/build.xml
      flex/sdk/trunk/frameworks/projects/rpc/manifest.xml
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/AbstractConsumer.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/xml/IXMLEncoder.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/xml/Schema.as
      flex/sdk/trunk/frameworks/projects/utilities/build.xml
      flex/sdk/trunk/frameworks/tests/checkinapp/checkinapp.css
      flex/sdk/trunk/frameworks/tests/checkinapp/checkinapp_testScript.mxml
      flex/sdk/trunk/frameworks/tests/componentSmoke/componentSmoke.css
      flex/sdk/trunk/in/player/lnx/flashplayer.tar.gz
      flex/sdk/trunk/in/player/lnx/libflashplayer.so.tar.gz
      flex/sdk/trunk/in/player/mac/Flash Player.app.zip
      flex/sdk/trunk/in/player/win/FlashPlayer.exe
      flex/sdk/trunk/kick-build.txt
      flex/sdk/trunk/modules/antTasks/src/flex/ant/CompcTask.java
      flex/sdk/trunk/modules/antTasks/src/flex/ant/MxmlcTask.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Evaluator.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/ReferenceValue.java
      flex/sdk/trunk/modules/compiler/build.xml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilationUnit.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerBenchmarkHelper.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/As3Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableExtension.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableFirstPassEval uator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/BindableSecondPassEva luator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingFirstPassE valuator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeFirstPassEva luator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/genext/GenerativeSecondPassEv aluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedFirstPassEvalu ator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/managed/ManagedSecondPassEval uator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/CompilerConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/DefaultsConfigurator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/NamespacesConfiguration.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/CssCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StyleDef.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/css/StylesContainer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/I18nCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/I18nUtils.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/PropertyText.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/PropertyTranslationFormat.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/i18n/TranslationFormat.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/AbstractTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/DataTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/ImageTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/MovieTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/media/SkinTranscoder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/AbstractGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Element.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlVisitor.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/HTTPServiceAnalyzer .java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/RemoteObjectAnalyze r.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/SyntaxAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/WebServiceAnalyzer. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AnonymousObjectGraph Builder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ArrayBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/HTTPServiceBuilder.j ava
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ModelBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/PrimitiveBuilder.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/RemoteObjectBuilder. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/WebServiceBuilder.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/XMLBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/Analyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/AnalyzerAdapter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/ArrayNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/DocumentNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/ModelNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/MxmlScanner.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/Node.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/PrimitiveNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/ScriptNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/SyntaxTreeBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/XMLListNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/XMLNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDef.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/DescriptorGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/AttributeHandler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/ChildNodeHandler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/DeclarationHandler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/FrameworkDefs.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/NodeTypeResolver.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/StandardDefs.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/TextParser.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/TypeCompatibility.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/ValueNodeHandler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Effect.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Event.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Property.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Style.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/TypeTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Array.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/DocumentInfo.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/EventHandler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Model.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MovieClip.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Primitive.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/decl/InitializedProperty Declaration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ArrayElementInitial izer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/DynamicPropertyInit ializer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/EffectInitializer.j ava
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/EventInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/Initializer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/NamedInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/StaticPropertyIniti alizer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/StyleInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/VisualChildInitiali zer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/MimeMappings.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/QName.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/ThreadLocalToolkit.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CopyLocale.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderConfiguration.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMConfiguration.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/TagDecoder.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/TagEncoder.java
      flex/sdk/trunk/mustella/MustellaResultsParser.java
      flex/sdk/trunk/mustella/mustella.swc
      Added Paths:
      flex/sdk/trunk/frameworks/fxg-manifest.xml
      flex/sdk/trunk/frameworks/gumbo-manifest.xml
      flex/sdk/trunk/frameworks/libs/flex4.swc
      flex/sdk/trunk/frameworks/libs/text_edit.swc
      flex/sdk/trunk/frameworks/libs/text_importExport.swc
      flex/sdk/trunk/frameworks/libs/text_model.swc
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/IStateClient2.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientStroke.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/RadialGradientStroke.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/SolidColorStroke.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/states/OverrideBase.as
      flex/sdk/trunk/in/player/10/lnx/install_flash_player_10_linux.tar.gz
      flex/sdk/trunk/in/player/lnx/install_flash_player_10_linux.tar.gz
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InvalidStateAttributeUsage.j ava
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InvalidStateSpecificValue.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MXMLNamespaces.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/DeclarationsNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/DefinitionNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/DesignLayerNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/LibraryNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/PrivateNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/ReparentNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/StateNode.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/StatesGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/reflect/Stateful.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/AtClear.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Reparent.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/StatesModel.java
