0 Replies Latest reply on Jul 14, 2008 11:50 AM by (Jim_Murphy)
    [svn] 2464: add flex 4 to trunk
    Level 1
      Revision: 2464
      Author: jimurphy@adobe.com
      Date: 2008-07-14 12:50:33 -0700 (Mon, 14 Jul 2008)
      Log Message:
      add flex 4 to trunk
      Added Paths:
      flex/sdk/trunk/frameworks/projects/flex4/
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/defaults.css
      flex/sdk/trunk/frameworks/projects/flex4/manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/
      flex/sdk/trunk/frameworks/projects/flex4/src/Flex4Classes.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Button.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/CheckBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/HScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ItemRenderer.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ItemsComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/List.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Panel.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/RadioButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Range.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Selector.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/Spinner.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextArea.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextInput.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextView.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/ToggleButton.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/VScrollBar.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Application.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Flags32.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/MXMLComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Skin.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/SkinnableComponent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Version.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/AddAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/AnimateProperties.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/Fade.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/PropertyValuesHolder.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/RemoveAction.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/AddActionInstance .as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/AnimateProperties Instance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/FadeInstance.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/effects/effectClasses/RemoveActionInsta nce.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/events/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/events/FlexEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/events/ItemExistenceChangedEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/events/TextOperationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/BaseDimensionFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/BaseFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/BevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/BlurFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/ColorMatrixFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/ConvolutionFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/DisplacementMapFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/DropShadowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/GlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/GradientBevelFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/GradientFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/GradientGlowFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/filters/IBitmapFilter.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/geom/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/geom/Transform.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/BitmapGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/CloseSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/CubicBezierSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Ellipse.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/FilledElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Graphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/IAssignableDisplayObjectElemen t.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/IDisplayObjectElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/IGraphicElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/IGraphicElementHost.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Line.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/LineSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/MaskType.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/MoveSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Parser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Path.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/PathSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/QuadraticBezierSegment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Rect.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/StrokedElement.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/TextBox.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/TextGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/TransformUtil.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/GraphicElement .as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/GraphicElement HostImpl.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextBlockCompo ser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextFlowCompos er.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextGraphicEle ment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/intf/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/intf/ILayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/intf/ILayoutItem.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/BasicLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/HorizontalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/LayoutItemFDO.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/LayoutItemFactory.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/LayoutItemHelper.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/LayoutItemUIC.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/layout/VerticalLayout.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ApplicationSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/CheckBoxSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/DefaultItemRenderer.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/HScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/HScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/HScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ItemsComponentSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ListSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/PanelSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/RadioButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ScrollBarDownButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ScrollBarLeftButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ScrollBarRightButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ScrollBarUpButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/SelectorSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/SpinnerDecrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/SpinnerIncrButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/SpinnerSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/TextAreaSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/TextInputSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ToggleButtonSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/VScrollBarSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/VScrollBarThumbSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/VScrollBarTrackSkin.mxml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/states/
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/states/AddItems.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/states/RemoveItems.as
