0 Replies Latest reply on Jul 14, 2008 5:16 PM by (Ryan_Frishberg)
    [svn] 2482: Fix up focus issues with the new Application.
      Revision: 2482
      Author: rfrishbe@adobe.com
      Date: 2008-07-14 18:16:25 -0700 (Mon, 14 Jul 2008)
      Log Message:
      Fix up focus issues with the new Application. Added tabChildren=true for group. Had to override Group's focusPane getter/setter b/c the UIComponent version uses addChild/removeChild which throws an RTE for Group. This should be revisited when focusPane is revisited (and maybe moved into the Skin...?)
      Based on some comments from Glenn, removed backgroundColorNumber and just use backgroundColor typed as an Object.
      QE: Yes - Will need to start writing tests for Application and focusing inside Groups
      Doc: No
      Reviewer: Glenn
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Application.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Group.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/skin/ApplicationSkin.mxml
