0 Replies Latest reply on Jul 15, 2008 10:52 AM by (Jono_Spiro)
    [svn] 2489: FB-13253 - Export Release Build produces bad SWFs when targeting player 10 and using SDK 3 .1.0 or 3.0.x
    Level 1
      Revision: 2489
      Author: jspiro@adobe.com
      Date: 2008-07-15 11:52:34 -0700 (Tue, 15 Jul 2008)
      Log Message:
      FB-13253 - Export Release Build produces bad SWFs when targeting player 10 and using SDK 3.1.0 or 3.0.x
      * FB exposed a bug in the compiler via a workflow that the compiler doesn't use -- it creates a new compiler configuration for the linking phase rather than using the original. However it uses compiler functions to "supply" the original compiler configuration; the compiler was ignoring the original settings related to target-player.
      Reviewer: Pete!
      Bugs: FB-13253
      QA: Yes, please run target-player tests. FB should run whatever tests they have related to debug and release builds.
      Doc: No
      Ticket Links:
      http://bugs.adobe.com/jira/browse/FB-13253
      Modified Paths:
      flex/sdk/branches/3.1.0/modules/compiler/src/java/flex2/tools/oem/internal/LinkerConfigur ation.java
