0 Replies Latest reply on Jul 16, 2008 5:25 AM by (Jim_Murphy)
    [svn] 2506: Merged 3.0.x revisions [2417,2458,2504] -> trunk
    Level 1
      Revision: 2506
      Author: jimurphy@adobe.com
      Date: 2008-07-16 06:25:03 -0700 (Wed, 16 Jul 2008)
      Log Message:
      -I also manually updated modules/compiler/src/java/flex2/tools/oem/internal/LinkerConfiguration.java to implement flex2.linker.LinkerConfiguration due to a name change in trunk
      -removed player 9 stuff
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/air-config.xml
      flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Panel.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Button.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/scrollClasses/ScrollBar.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/scrollClasses/ScrollThumb.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/FlexModuleFactory.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/events/MarshalMouseEvent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/CursorManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/DragManagerImpl.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/SystemManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/managers/dragClasses/DragProxy.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/resources/IResourceManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/resources/ResourceManagerImpl.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/Channel.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/messaging/ChannelSet.as
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/xml/XMLDecoder.as
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/ContextStatics.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LinkerConfiguration.jav a
      flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/DependencyChecker.jav a
      flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/FrameworkSwcDependenc yRules.java
      flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/nodes/DefNode.java
      flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/nodes/DepNode.java
      flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/nodes/DependencyNode. java
      flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/nodes/LibrariesNode.j ava
      flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/nodes/LibraryNode.jav a
      flex/sdk/trunk/tools/dependencychecker/flex/tools/dependencychecker/nodes/ScriptNode.java
      Added Paths:
      flex/sdk/trunk/development/eclipse/flex/airframework/
      flex/sdk/trunk/development/eclipse/flex/airframework/.actionScriptProperties
      flex/sdk/trunk/development/eclipse/flex/airframework/.flexLibProperties
      flex/sdk/trunk/development/eclipse/flex/airframework/.project
      flex/sdk/trunk/development/eclipse/flex/airframework/.settings/
      flex/sdk/trunk/development/eclipse/flex/airframework/.settings/org.eclipse.core.resources .prefs
      flex/sdk/trunk/frameworks/projects/framework/src/mx/resources/LocaleSorter.as
      flex/sdk/trunk/in/player/mac/Install Flash Player 10 UB.dmg
      flex/sdk/trunk/in/player/win/Install Flash Player 10 ActiveX.exe
      flex/sdk/trunk/in/player/win/Install Flash Player 10 Plugin.exe
      Removed Paths:
      flex/sdk/trunk/frameworks/libs/player/9/
      flex/sdk/trunk/in/player/10/lnx/Flash Player.app.zip
      flex/sdk/trunk/in/player/lnx/install_flash_player_9_linux.tar.gz
      flex/sdk/trunk/in/player/mac/Install Flash Player 9 UB.dmg
      flex/sdk/trunk/in/player/win/Install Flash Player 9 ActiveX.exe
      flex/sdk/trunk/in/player/win/Install Flash Player 9 Plugin.exe
      Property Changed:
      flex/sdk/trunk/
