0 Replies Latest reply on Jul 16, 2008 1:38 PM by (Jono_Spiro)
    [svn] 2514: frameworks: Fixing injection I made ages ago in build. xmls for framework projects
    Level 1
      Revision: 2514
      Author:   jspiro@adobe.com
      Date:     2008-07-16 14:38:06 -0700 (Wed, 16 Jul 2008)
      Log Message:
      frameworks: Fixing injection I made ages ago in build.xmls for framework projects
      * all the projects should have been building against player 9's playerglobal.swc, not player 10's (except for flex4.swc)
      * this might fix compiling problems that developed in tests for air
      * problem was that s in ant are immutable and don't fire a warning if you redeclare them with a different value. I thought I was overriding the global ${playerglobal.version} property in files that needed to make it 9 instead of 10
      * solution: created global.playerglobal.version (which is 10) and in files that need to "override" it, I declare local.playerglobal.version locally.
      Reviewer: Pete
      Bugs: n/a
      QA: Please retest air compiling problems. We should probably re-run everything, since we're going back to the correct playerglobal, stuff might get fixed, stuff shouldn't (but could) get broken.
      Doc: No
      Modified Paths:
          flex/sdk/trunk/build.properties
          flex/sdk/trunk/frameworks/build_framework.xml
          flex/sdk/trunk/frameworks/projects/airframework/build.xml
          flex/sdk/trunk/frameworks/projects/flash-integration/build.xml
          flex/sdk/trunk/frameworks/projects/flex/build.xml
          flex/sdk/trunk/frameworks/projects/flex4/build.xml
          flex/sdk/trunk/frameworks/projects/framework/build.xml
          flex/sdk/trunk/frameworks/projects/haloclassic/build.xml
          flex/sdk/trunk/frameworks/projects/rpc/build.xml
          flex/sdk/trunk/frameworks/projects/utilities/build.xml
