0 Replies Latest reply on Feb 27, 2008 1:58 PM by (Paul_Reilly)
    [svn] 684: Add javadoc target to build.xml and scrubbed javadoc comments.
    Level 1
      Revision: 684
      Author: preilly@adobe.com
      Date: 2008-02-27 13:58:19 -0800 (Wed, 27 Feb 2008)
      Log Message:
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/modules/compiler/src/java/flash/swf/tools/as3/EvaluatorAdapter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/API.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SourcePath.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/abc/Compiler.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SignatureEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationBuffer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AnonymousObjectGraph Builder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ApplicationBuilder.j ava
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ArrayBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/Builder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ComponentBuilder.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ModelBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/PrimitiveBuilder.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/RemoteObjectBuilder. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ServiceRequestBuilde r.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/WebServiceBuilder.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/XMLBuilder.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Array.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MovieClip.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/VariableDeclaration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.ja va
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/VisualChildInitiali zer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/Swc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcDirectoryArchive.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcMovie.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/MultiName.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/NameFormatter.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/QName.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/DependencyWalker.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CopyLocale.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderApplication.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderConfiguration.jav a
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/flexbuilder/BuilderLibrary.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/graphics/images/ImageUtil.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/DebugEncoder.java
