0 Replies Latest reply on Jul 25, 2008 10:17 AM by (Darrell_Loverin)
    [svn] 2630: Implement part one of MarshalPlan MouseOut behavior and fix bugs.
      Revision: 2630
      Author: dloverin@adobe.com
      Date: 2008-07-25 11:17:25 -0700 (Fri, 25 Jul 2008)
      Log Message:
      ?\226?\128?\162 Did the PopUpManager side of the changes to MarshalMouseEvent.MOUSE_DOWN will work. I will fix up the uses of FlexMouseEvent.MOUSE_DOWN_OUTSIDE in the Framework in another set of changes.
      ?\226?\128?\162 Clean up PopUpManagerImpl.
      ?\226?\128?\162 Fixed a bug displaying a modal window from A.2.3. The problem was A.2 sending the CREATE modal request to A and A not being a to create the correct size hole in the modal because it did not know the size of A.2?\226?\128?\153s SWFLoader. So now A.2 will pass up a rectangle to exclude to A. The rectangle is only passed with a sandbox for security reasons.
      QE:Verify a modal dialog from A.2.3.
      Doc: For pop up behavior to work every application will need to include PopUpManager in their application. Even if their application does not use pop ups, a marshal plan application may need to use their PopUpManager.
      Checkintests: Yes
      Reviewer: Alex
      Bugs:
      Modified Paths:
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/events/ModalWindowRequest.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/managers/PopUpManagerImpl.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/managers/SystemManager.as
