0 Replies Latest reply on Feb 28, 2008 5:28 PM by (Jono_Spiro)
    [svn] 689: Turning on Java assertions for development via the setup. sh script; if you're using Commant Prompt or you do not use `source setup. sh` then you will not be affected.
    Level 1
      Revision: 689
      Author: jspiro@adobe.com
      Date: 2008-02-28 17:28:54 -0800 (Thu, 28 Feb 2008)
      Log Message:
      Turning on Java assertions for development via the setup.sh script; if you're using Commant Prompt or you do not use `source setup.sh` then you will not be affected.
      * If using CP, you can enable assertions by adding "-ea" to the end of java.args in bin/jvm.config
      * If you're using a bash shell: `export SETUP_SH_VMARGS="-ea"`
      Modified Paths:
      flex/sdk/trunk/bin/amxmlc
      flex/sdk/trunk/bin/compc
      flex/sdk/trunk/bin/fcsh
      flex/sdk/trunk/bin/mxmlc
      flex/sdk/trunk/setup.sh
