0 Replies Latest reply on Aug 1, 2008 1:12 PM by (Paul_Reilly)
    [svn] 2710: Fixed 3.1. 0 by reverting to the old behaviour when writing out debug
    Level 1
      Revision: 2710
      Author: preilly@adobe.com
      Date: 2008-08-01 14:12:55 -0700 (Fri, 01 Aug 2008)
      Log Message:
      Fixed 3.1.0 by reverting to the old behaviour when writing out debug
      line numbers. This prevents the player from seeing -1, which was
      causing hangs/crashes. The real fix is to track down where synthetic
      functions are getting generated and make them not debuggable, so they
      don't reuse the debug line numbers from previous debuggable functions.
      This will be done in trunk in a follow on checkin.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-16323
      API Change: NO
      Reviewer: jspiro
      Code-level description of changes:
      Modified setPosition() and clearPositionInfo() to no longer set the
      debug_linenum to -1.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16323
      Modified Paths:
      flex/sdk/branches/3.1.0/lib/asc.jar
      flex/sdk/branches/3.1.0/modules/asc/src/java/macromedia/asc/embedding/avmplus/ActionBlock Emitter.java
