0 Replies Latest reply on Aug 1, 2008 1:59 PM by (Darrell_Loverin)
    [svn] 2713: Show Alerts using existing modal window code instead of using ShowAlertRequest .
      Revision: 2713
      Author: dloverin@adobe.com
      Date: 2008-08-01 14:59:17 -0700 (Fri, 01 Aug 2008)
      Log Message:
      Show Alerts using existing modal window code instead of using ShowAlertRequest.
      QE:YES. Test alerts from all application nodes types. Alerts should be centered in the
      visible portion of the sandbox root. Test showing alerts where the parent argument is a
      sandbox root, a UIComponent, and a display object that is not a UIComponent.
      Doc:
      Checkintests: Standard plus PopUpManager.
      Reviewer: Alex
      Bugs:
      WindowedSystemManager:
      Implement getVisibleApplicationRect().
      Alert.as
      Remove ShowAlertRequest. Modifiy centerPopUp() to send within the visible
      SWFLoader.as
      Implement IApplicationLoader.
      UIComponent.as
      getVisibleRect() returns the rectangle in global coordinates.
      SandboxBridgeRequest.as
      Add GET_VISIBLE_RECT request.
      FocusManager.as
      Remove request handling for the showAlertRequest. Replace IFocusManagerBridge
      is IApplicationLoader. IFocusManagerBridge will be removed.
      ISystemManager2.as
      add new method:
      function getVisibleApplicationRect(bounds:Rectangle = null):Rectangle;
      PopUpManagerImpl:
      Modify centerPopUp() to center within the visible portion of the parent.
      Allow the parent of a dialog to be the sandbox root.
      Move preProcessModalWindowRequest to SystemManager so PopUpManager only need to be
      in the sandbox root.
      SystemChildrenList.as
      Fix RTE when owner == child.
      SystemManager.as
      Handle requests for SandboxBridgeRequest.GET_VISIBLE_RECT.
      Add sandboxRoot requests: "isTopLevelRoot" and "getVisibleApplicationRect".
      SystemManagerProxy.as
      override getVisibleApplicationRect().
      Modified Paths:
      flex/sdk/branches/3.0.x/frameworks/projects/airframework/src/mx/managers/WindowedSystemMa nager.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/controls/Alert.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/controls/SWFLoader.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/events/SandboxBridgeRequest. as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/managers/FocusManager.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/managers/ISystemManager2.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/managers/PopUpManagerImpl.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/managers/SystemChildrenList. as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/managers/SystemManager.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/managers/SystemManagerProxy. as
      Added Paths:
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/core/IApplicationLoader.as
      Removed Paths:
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/events/ShowAlertRequest.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/managers/IFocusManagerBridge .as
