0 Replies Latest reply on Aug 5, 2008 6:50 AM by (Paul_Reilly)
    [svn] 2740: This should fix OEM library compilation.
    Level 1
      Revision: 2740
      Author: preilly@adobe.com
      Date: 2008-08-05 07:50:13 -0700 (Tue, 05 Aug 2008)
      Log Message:
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: fix for SDK-16116 fix
      API Change: NO
      Reviewer: cframpto (in progress)
      Code-level description of changes:
      CompcConfiguration.java
      Added static variable, outputRequired, so that subclasses can
      override the default behavior.
      Modified validate() by pulling input validation out into new
      helper method, validateSwcInputs().
      LibraryCompilerConfiguration.java
      Added static block to override outputRequired.
      Added override for validateSwcInputs().
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16116
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/CompcConfiguration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/LibraryCompilerConfigur ation.java
