0 Replies Latest reply on Aug 6, 2008 12:05 AM by (Paul_Reilly)
    [svn] 2753: tests Passed: checkintests, asc-tests
    Level 1
      Revision: 2753
      Author: preilly@adobe.com
      Date: 2008-08-06 01:05:35 -0700 (Wed, 06 Aug 2008)
      Log Message:
      Needs QA: YES
      Needs DOC: NO
      Bug fixes: SDK-16319
      API Change: NO
      Reviewer: jspiro
      Code-level description of changes:
      asc/src/java/macromedia/asc/parser/Parser.java
      Modified parseAnnotatedDirectiveOrStatement() to handle parsing a
      code fragment, like CONFIG::foo, by returning the
      ExpressionStatementNode.
      compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      Modified parse() to return an empty list if there are no results
      and to start with an ArrayList of size 1 otherwise.
      compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension.java
      Modified generateAccessorFunction() to be more bullet proof by
      using !isEmpty() instead of size() == 1.
      compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Modified calls to AbstractSyntaxTreeUtil.parse() to check for an
      empty list result before accessing the first element.
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16319
      Modified Paths:
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/binding/DataBindingExtension. java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
