0 Replies Latest reply on Aug 6, 2008 9:46 AM by (Chris_Peyer)
    [svn] 2760: migrate sanity tests to use the runtest.py harness
      Revision: 2760
      Author: cpeyer@adobe.com
      Date: 2008-08-06 10:46:43 -0700 (Wed, 06 Aug 2008)
      Log Message:
      Modified Paths:
      flex/sdk/trunk/modules/asc/test/compiler/as3/Expressions/QualifiedReferences/DoubleQualif iedReferenceErr.err
      flex/sdk/trunk/modules/asc/test/compiler/bugs/ASC-2802.err
      flex/sdk/trunk/modules/asc/test/compiler/bugs/ASC-3310.err
      flex/sdk/trunk/modules/asc/test/compiler/runtests.py
      flex/sdk/trunk/modules/asc/test/compiler/testconfig.txt
      Added Paths:
      flex/sdk/trunk/modules/asc/test/compiler/sanity/
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideBaseNew.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideBaseNew.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideBaseOld.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideBaseOld.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideClass.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideClass.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideClass.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideClass_fail.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideClass_fail.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideClass_fail.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceGetter.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceGetter.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceGetter.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceGetter_fail.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceGetter_fail.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceGetter_fail.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceMethod.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceMethod.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceMethod.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceMethod_fail.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceMethod_fail.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceMethod_fail.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceSetter.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceSetter.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceSetter.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceSetter_fail.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceSetter_fail.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/IllegalOverrideInterfaceSetter_fail.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/arguments.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/arguments.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/arguments.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/arguments2.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/arguments2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/arguments2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/asDoc.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/asDoc.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/asDoc.xml
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b107194.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b107194.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b108022.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b108022.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b108022.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b108798.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b108798.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b108798.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b111262.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b111262.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b111651.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b111651.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b111679.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b111679.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b111951.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b111951.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b111951.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b113887.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b113887.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b113887.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b114774.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b114774.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b114774.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b116702.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b116702.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b116702.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b118175.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b118175.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b118175.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120414.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120414.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120414.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120414_unix.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120414_unix.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120414_unix.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120429.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120429.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120429.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120429_unix.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120429_unix.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120429_unix.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120430.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120430.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120430.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120430_unix.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120430_unix.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120430_unix.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120523.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120523.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120523.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120524.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120524.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120524.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120576.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120576.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b120576.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b124435.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b124435.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b124435.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b124561.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b124561.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b124561.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b127559.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b127559.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b127559.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b128275.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b128275.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b128275.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b134359.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b134359.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b134359.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b135181.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b135181.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b135181.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b137659.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b137659.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b137659.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b138992.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b138992.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b147398.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b147398.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b147398.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b148822.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b148822.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b148822.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b149131.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b149131.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b149131.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b149448.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b149448.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b151269.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b151269.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b151269.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b151539.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b151539.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b151539.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b152173.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b152173.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b152173.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b153336.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b153336.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b153336.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b153874.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b153874.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b153874.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b154869.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b154869.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b154869.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b159449.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b159449.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b159449.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b168157.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b168157.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/b168157.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/boolean.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/boolean.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/boolean.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/bug123884-import.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/bug123884-import.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/bug123884.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/bug123884.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/bug123884.log
      flex/sdk/trunk/modules/asc/test/compiler/sanity/call.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/call.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/call.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/class1.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/class1.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/class1.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/class_ctor.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/class_ctor.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/class_ctor.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/closure.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/closure.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/closure.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/coerce.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/coerce.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/coerce.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/const.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/const.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/const.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/constClass.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/delete.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/delete.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/delete.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/doubleToInt.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/doubleToInt.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/doubleToInt.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/dynamic.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/dynamic.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/dynamic.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/equals.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/equals.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/equals.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/exceptions.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/exceptions.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/exceptions.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/fexpr.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/fexpr.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/fexpr.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/flowConst.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/flowConst.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/for_slow.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/for_slow.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/for_slow.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/forin.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/forin.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/forin.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/forin2.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/forin2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/forin2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/get.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/get.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/get.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/harness.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/harness.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/harness.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/harnessASC.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/harnessASC.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/harnessASC.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/hello.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/hello.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/hello.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder-a.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder-a.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder-abc.log
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder-b.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder-b.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder.log
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder_abc.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder_abc.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/importorder_abc.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/incr.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/incr.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/incr.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/init.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/init.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/init.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/invalidtypeexpr.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/invalidtypeexpr.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/member.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/member.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/member.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/metadata2.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/metadata2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/metadata2.log
      flex/sdk/trunk/modules/asc/test/compiler/sanity/offsetStringTests.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/offsetStringTests.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/offsetStringTests.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/overwrite.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/overwrite.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/overwrite.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/pkg_missing.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/pkg_missing.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/plus2.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/plus2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/plus2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/pnf.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/pnf.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/pnf.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/proto.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/proto.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/proto.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/rest.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/rest.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/rest.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/restarg.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/restarg.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/set.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/set.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/set.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/shell.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/shellASC.abc
      flex/sdk/trunk/modules/asc/test/compiler/sanity/shellASC.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/1.out
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/2.out
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/3.out
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/RegExpUnicodeWhiteSpace.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/RegExpUnicodeWhiteSpace.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/accessqualifiers.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/accessqualifiers.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/arguments.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/arguments2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/array.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/array.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/array2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/array2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/arrayextensions.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/arrayextensions.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/arrayliteral.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/arrayliteral.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/as.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/as.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/asDoc.xml
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b107194.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b107938.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b107938.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b107979.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b107979.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b107980.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b107980.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b108022.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b108470.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b108470.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b108631.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b108631.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b108798.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b109167.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b109167.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b109167_in.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b109751.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b109751.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b110112.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b110112.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b110112_i.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b111199.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b111199.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b111261.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b111261.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b111413.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b111413.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b111951.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b112173.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b112173.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b112393.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b112393.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b113192.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b113887.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b114584.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b114584.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b114774.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115155.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115155.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115412.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115412.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115530.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115530.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115584.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115584.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115876.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115876.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115964.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115964.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b116702.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b117267.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b117267.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b117268.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b117268.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b118175.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120414.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120414_unix.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120428.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120428.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120428_unix.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120428_unix.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120429.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120429_unix.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120430.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120430_unix.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120449.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120449.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120523.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120524.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b120576.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b121234.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b121234.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b121391.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b121391.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b121469.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b121469.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b122038.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b122038.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b124435.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b124561.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b124583.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b124583.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b124585.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b124585.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b127174.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b127174.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b127559.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b128275.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b129633.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b129633.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b130764.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b130764.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b132189.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b132189.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b132771.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b132771.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b132818.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b132818.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b134151.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b134151.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b134359.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b134361.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b134361.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b134539.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b134539.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b136054.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b136054.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b136765.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b136765.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b137604.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b137604.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b137659.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b137800.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b137800.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b137879.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b137879.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b137879.il
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b137879.p
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b138386.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b139065.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b139065.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b139770.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b139770.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b142772.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b142772.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b147398.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b148822.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b149131.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b150025.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b150032.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b150032.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b150975.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b151269.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b151539.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b152030.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b152030.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b152173.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b152594.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b152594.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b152915.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b152915.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b152925.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b152925.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b153336.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b153874.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154156.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154156.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154298.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154298.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154312.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154312.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154319.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154319.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154771.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154771.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b154869.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b155288.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b158169.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b158305.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b158305.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b159449.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b159745.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b159745.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b161702.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b161702.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b161825.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b161825.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b164538.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b164538.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b168157.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b172372.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b172372.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b181292.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b181292.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b191112-import.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b191112.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b198376.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b198376.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b204297.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b204297.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/badSwitch.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bignumber.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bignumber.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bigobj.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bigobj.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bigstring.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bigstring.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/binary.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/binary.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/block_err.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/block_err.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/block_names.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/block_names.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/block_names_err.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/block_names_err.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/boidshack.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/boidshack.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bool.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bool.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/boolean.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bound.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bound.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/break.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/break.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/break_in_try.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/break_in_try.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bug109296.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/bug109296.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/call.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/catchReturnVoid.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/catchReturnVoid.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/class1.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/class3.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/class3.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/class4.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/class4.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/class_ctor_strict.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/class_ctor_strict.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/closure.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/cls_fwdref.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/cls_fwdref.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/coerce.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/completion.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/completion.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/compound.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/compound.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/cond.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/cond.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/const.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/constClass.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/constClass.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/continue.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/continue.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/continue_err.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/continue_err.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/delete.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/dict.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/dict.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/do.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/do.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/doubleToInt.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/dynamic.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/empty.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/enum.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/enum.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/equals.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/error.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/error.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/exception_scope.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/exception_scope.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/exceptions.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/fexpr.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/finally-nested.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/finally-nested.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/flength.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/flength.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/for.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/for.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/for_fast.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/for_fast.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/for_slow.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/forin.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/forin2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/func.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/func.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/get.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/getset.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/getset.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/getstmt.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/getstmt.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/harness.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/harnessASC.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/if.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/if.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/import.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/import.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/incr.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/index.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/index.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/indexed.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/indexed.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/init.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/integerHashTableKeys.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/integerHashTableKeys.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface3.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface3.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_ns.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_ns.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_ns_error.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_ns_error.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_override.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_override.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_simple.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_simple.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_super.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/interface_super.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/intrinsic.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/intrinsic.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/invalidtypeexpr.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/itable.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/itable.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/label.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/label.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/label_err.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/label_err.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/largeIntegerConversions.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/largeIntegerConversions.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/local.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/local.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/locale.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/locale.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/member.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/metadata.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/mod.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/mod.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/namedFuncExpr.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/namedFuncExpr.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/namespace-alias.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/namespace-alias.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/namespace.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/namespace.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/namespaces2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/namespaces2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/nan_sense.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/nan_sense.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/native.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/native.cpp
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/native.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/native.h
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/nested.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/nested.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/nested2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/nested2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/new.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/new.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/nothing.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/object.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/object.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/objectliteral.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/objectliteral.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/offsetStringTests.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/optionalargs.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/optionalargs.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/override-protected.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/override-protected.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/override_err.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/override_err.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/overwrite.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/package.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/package.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/package_doccomment.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/package_doccomment.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/parseFloatVsNumber.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/parseFloatVsNumber.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/plus.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/plus.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/plus2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/powpow.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/powpow.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/prime.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/prime.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/prime_int.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/prime_int.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/prime_number.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/prime_number.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/private.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/private.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/protected.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/protected.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/proto.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/prototype_attr.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/prototype_attr.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/regexp.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/regexp.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/regexp_zeroWidthLookahead.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/regexp_zeroWidthLookahead.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/regress.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/regress.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/reservedquals.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/reservedquals.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/rest.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/restarg.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/ret.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/ret.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/returnTypeInWith.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/sanity.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/sanity.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/set.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/shift.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/shift.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/simple.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/simple.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/split.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/split.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/staranno.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/staranno.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/statics_and_namespaces.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/statics_and_namespaces.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/str.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/str.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/strict/
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/stringEscapes.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/stringEscapes.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/subtle_finally.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/subtle_finally.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/super.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/super.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/super2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/super2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/super3.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/super3.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/super_err.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/super_err.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/swap.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/swap.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/switch.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/t1.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/t1.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/t2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/t3.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/t3.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/t4.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/t4.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/t5.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/t5.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/this.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/this.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/this2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/this2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/toStringRadix.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/trycatch.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/trycatch.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/tryfinallyloop.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/tryfinallyloop.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/typeConversion.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/typeConversion.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/uint.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/uint.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/unary.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/unary.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/unbound.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/unused/
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/unused/decimal1.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/unused/es4-initlist.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/unused/es4-initlistnosuper.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/unused/es4-propiniterror.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/unused/es4-thisInInit.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/usebeforeInit.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/vars.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/vars.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/vector.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/vector.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/versions.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/versions.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/void.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/void.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/while.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/while.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/with.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/with.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/xml_dynamic.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/xml_dynamic.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/xmlfilter.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/xmlfilter.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/xmlfixes.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/xmlfixes.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/xmlname.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/xmlname.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/switch.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/switch.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/t2.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/t2.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/toStringRadix.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/toStringRadix.err
      flex/sdk/trunk/modules/asc/test/compiler/sanity/unbound.as
      flex/sdk/trunk/modules/asc/test/compiler/sanity/unbound.err
      Removed Paths:
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/AccPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ActivateTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/AddListenerWarn2_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/AddedTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ArgCallerWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/AsBroadcasterClassWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/BitmapDataWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/BooleanWithNoArgWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ButtonMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMactive_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMbutton_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMcall_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMcapabilities_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMcolor_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMloadVars_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMmovieClipLoader_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMmovieclip_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMnetStream_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMobject_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMselection_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMsharedObject_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMsound_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMstage_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMstylesheet_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMsubstring_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMsystem_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMtextField_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMtextFormat_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMtimeout_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMtrace_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMvideo_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMxmlSocketTest_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMxml_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CMxmldoc_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CameraEventsWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CameraGetWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CancelTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ChangeTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CharCodeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ChrWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ClearIntervalWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CloseTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ColorMethodsWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ComparisonWithUndefWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/CompleteTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ConnectTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContainerMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContainerPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuCopyWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuEventsWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuForward_BackWarn_warning s.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuItemCopyWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuItemEventsWarn_warnings. txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ContextMenuMethodsWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DateWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DeactivateTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DeleteKeyWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DiffDataTypesWithNullUndefinedWarn_ warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectAlphaWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectHeightWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectMaskWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectMouseXWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectMouseYWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectNameWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectParentWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectRotationWarn_warnings. txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectScaleXWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectScaleYWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectVisibleWarn_warnings.t xt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectWidthWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectXWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DisplayObjectYWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/DuplicateMovieClipWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/EnterFrameTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FileReferenceEventsWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FileReferenceListWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FileReferenceMethodsWarn_warnings.t xt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FocusInTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FocusOutTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/FocusRectPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ForInOrderingWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GetCodeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GetPropertyWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GlobalFunctionsWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GotoAndPlayWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/GotoAndStopWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/HighQualityPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/IMEMethodsWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/Id3TypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageFilterMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageFilterPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageLoaderInfoMethWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageLoaderInfoPropWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImagePropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageSpriteMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImageSpritePropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImeEventMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ImeEventPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/InitTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/IsDownWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/IsToggledWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyFocusChangeTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyboardClassConstWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/KeyboardClassMethodsWarn_warnings.t xt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LengthWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LevelPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LineMetricsMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ListPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LoadMovieNumWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LoadMovieWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LoadVariablesWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LoadVarsMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LoadVarsPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/LocalConnectionWarnings_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MaxScrollPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MbChrWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MbLengthWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MbOrdWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MbSubStringWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MenuEventMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MenuEventPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MicrophoneEventsMethodsWarn_warning s.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MissingNamespaceDecWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MouseClassEventsMethodsWarn_warning s.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MouseFocusChangeTypeWarn_warnings.t xt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MouseLeaveTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MovieClipEvents_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MovieclipLoaderClassWarn_warnings.t xt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/MovieclipUrlWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/NetConnIsConnectedPropWarn_warnings .txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/NewlinePropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/NextFrameWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/NumPadWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/NumberWithWhiteSpaceInArgWarn_warni ngs.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/OpenTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/OrdWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PGDNWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PGUPWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ParentPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PlayWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PrintAsBitmapNumWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PrintAsBitmapWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PrintNumWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/PrintWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ProtoPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/QualityPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/RandomWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/RemoveMovieclipWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/RemovedTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/RenderTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ResizeTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/RootPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ScalingGridPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ScrollPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ScrollTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SelectTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SetIntervalWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SetPropertyWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SocketIsConnectedPropWarn_warnings. txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SoundCompleteTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StagePropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StageQualityWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StartDragWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StopAllSoundsWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StopDragWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/StopWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SubStringWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SystemCapabilitiesMethWarn_warnings .txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/SystemCapabilitiesPropWarn_warnings .txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TabChildrenChangeTypeWarn_warnings. txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TabEnabledChangeTypeWarn_warnings.t xt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TabIndexChangeTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TargetPathPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextExtentsMethWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextExtentsPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextFieldBottomScrollPropWarn_warni ngs.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextFieldScrollPropWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextSnapshotClassWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/TextSnapshotMethodsWarn_warnings.tx t
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/ToggleHighQualityWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/URLStreamIsConnectedPropWarn_warnin gs.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/UnloadMovieNumWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/UnloadTypeWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/UnsupportedAS2FunctionWarn_warnings .txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/UnsupportedAS2PropertyWarn_warnings .txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/VersionPropWarn_warnings.txt
      flex/sdk/trunk/modules/asc/test/compiler/as3/Warnings/XYZQualityWarn_warnings.txt
      Property Changed:
      flex/sdk/trunk/modules/asc/test/compiler/es4/conditionalcompilation/
