0 Replies Latest reply on Aug 6, 2008 1:45 PM by (Jono_Spiro)
    [svn] 2769: SDK-15314 - fdb is outputting additional information on framework classes using the "info sources" switch
    Level 1
      Revision: 2769
      Author: jspiro@adobe.com
      Date: 2008-08-06 14:45:47 -0700 (Wed, 06 Aug 2008)
      Log Message:
      * We were outputting classes in the "flex" and "text" packages. Unfortuantely excluded classes are hard-coded in fdb, but I improved on the mechanism by putting excluded packages in a const array.
      * Improved the detection mechanism to use actual package names as discovered by fdb rather than the path of the class. Previously, having "mx" at any level in the path would mark the file as a framework class and exclude it; now the package name must *begin* with "mx" (or "flex" or "text").
      * Removed a defunct test for the file name being "frameworks.as".
      NOTE: "text" is **temporary** until Vellum's package is finalized. I will file a separate bug to track this.
      Bugs: SDK-15314
      QA: Yes, please run the fdb suite.
      Doc: No
      Reviewer: mikemo
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-15314
      Modified Paths:
      flex/sdk/trunk/modules/debugger/src/java/flex/tools/debugger/cli/DebugCLI.java
