0 Replies Latest reply on Aug 7, 2008 9:41 PM by (GordonSmith)
    [svn] 2782: Added localizations of the 13 .properties files in modules/ compiler for 13 new locales: Danish, German, Spanish, Finnish, French, Italian, Korean, Norwegian, Dutch, Portuguese, Swedish, Traditional Chinese, and Simplified Chinese.
    Level 1
      Revision: 2782
      Author: gosmith@adobe.com
      Date: 2008-08-07 22:41:14 -0700 (Thu, 07 Aug 2008)
      Log Message:
      Added localizations of the 13 .properties files in modules/compiler for 13 new locales: Danish, German, Spanish, Finnish, French, Italian, Korean, Norwegian, Dutch, Portuguese, Swedish, Traditional Chinese, and Simplified Chinese. These files were provided by the LCDS team.
      The Ant script for modules/compiler does not yet build locale JARs from these files.
      Reviewer: None needed
      Bugs: -
      QA: No
      Doc: No
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flash/css_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flash/css_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_da. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_de. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_es. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fi. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_fr. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_it. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_ko. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nb. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_nl. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_pt. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_sv. properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/config/ConfigurationException_zh_ tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/swc/SwcException_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker/LinkerException_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/linker_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDoc_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/DigestTool_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc_zh_tw.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_da.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_de.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_es.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_fi.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_fr.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_it.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_ko.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_nb.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_nl.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_pt.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_sv.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_zh_cn.properties
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools_zh_tw.properties
