0 Replies Latest reply on Aug 8, 2008 8:56 AM by (Dan_Schaffer)
    [svn] 2785: update clover code coverage report, add tests for asc commandline arguments
      Revision: 2785
      Author: dschaffe@adobe.com
      Date: 2008-08-08 09:56:23 -0700 (Fri, 08 Aug 2008)
      Log Message:
      Modified Paths:
      flex/sdk/trunk/modules/asc/build/java/build.xml
      flex/sdk/trunk/modules/asc/test/compiler/runtests.py
      flex/sdk/trunk/modules/asc/test/compiler/testconfig.txt
      Added Paths:
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/abcfuture.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/avmtarget.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/avmtarget.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/avmtargetn.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/avmtargetn.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/config.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/config.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/exe.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/exe.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/help1.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/help1.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/help2.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/help2.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/m.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/metadata.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/movieclip.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/sanity.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/sanity.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/show_bytes.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/show_flow.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/show_flow.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/show_instructions.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/show_parse_trees.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/show_parse_trees.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/static_semantics.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/static_semantics.err
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/swf.as
      flex/sdk/trunk/modules/asc/test/compiler/cmdline/swf.err
