0 Replies Latest reply on Aug 12, 2008 11:01 AM by (Darrell_Loverin)
    [svn] 2818: Fix up the remaining uses of stage that might cause a security violation.
    Level 1
      Revision: 2818
      Author: dloverin@adobe.com
      Date: 2008-08-12 12:01:36 -0700 (Tue, 12 Aug 2008)
      Log Message:
      QE: YES
      Doc:
      Checkintests: YES
      Reviewer: Alex
      Bugs:
      mx/controls/DataGrid.as
      mx/controls/List.as
      Listen to mouse down on sandbox root instead of systemManager. Fix remove listener code.
      mx/controls/sliderClasses/SliderThumb.as
      Listen to mouse down on sandbox root instead of systemManager. Remove stage listener for MOUSE_MOVE since
      systemManager will add a stage listener automatically if the caller has access to the stage.
      mx/preloaders/DownloadProgressBar.as
      Use the DownloaderProgressBar's stageWidth/stageHeight properties instead of directly accessing the stage.
      Modified Paths:
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/controls/DataGrid.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/controls/List.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/controls/sliderClasses/Slide rThumb.as
      flex/sdk/branches/3.0.x/frameworks/projects/framework/src/mx/preloaders/DownloadProgressB ar.as
