0 Replies Latest reply on Aug 14, 2008 5:55 AM by (Paul_Reilly)
    [svn] 2842: More whitespace normalization and removed qualification from names
      Revision: 2842
      Author: preilly@adobe.com
      Date: 2008-08-14 06:55:38 -0700 (Thu, 14 Aug 2008)
      Log Message:
      that were already imported. For example flex2.compiler.CompilerAPI
      was changed to CompilerAPI. This should make the code less verbose.
      tests Passed: checkintests
      Needs QA: NO
      Needs DOC: NO
      API Change: NO
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
