0 Replies Latest reply on Aug 15, 2008 6:30 AM by (Paul_Reilly)
    [svn] 2849: Added new benchmarking for capturing the time spent before and after
      Revision: 2849
      Author: preilly@adobe.com
      Date: 2008-08-15 07:30:02 -0700 (Fri, 15 Aug 2008)
      Log Message:
      CompilerAPI.compile(). It's not perfect, because it has to wait until
      the configuration is processed to know whether benchmarking is
      enabled, but it should be good for tracking improvements to
      incremental compilation.
      Here is how it can be used from a OEM Compiler API client:
      Benchmark benchmark = ThreadLocalToolkit.getBenchmark();
      System.out.println("precompile: " + benchmark.getTime(Benchmark.PRECOMPILE));
      System.out.println("postcompile: " + benchmark.getTime(Benchmark.POSTCOMPILE));
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: dloverin
      Code-level description of changes:
      tools/oem/Application.java
      tools/oem/Library.java
      tools/Compc.java
      tools/Mxmlc.java
      tools/Fcsh.java
      At each entry point, Benchmark.startTime(Benchmark.PRECOMPILE) is
      called. Just before CompilerAPI.compile() is called,
      Benchmark.stopTime(Benchmark.PRECOMPILE) is called. Just after
      CompilerAPI.compile(), Benchmark.startTime(Benchmark.POSTCOMPILE)
      is called. Before finishing up,
      Benchmark.stopTime(Benchmark.POSTCOMPILE) is called.
      compiler/CompilerAPI.java
      Modified runBenchmark() to return the new Benchmark object.
      compiler/util/ThreadLocalToolkit.java
      Modified log(ILocalizableMessage) and log(ILocalizableMessage,
      String) to check for a null logger. OEMUtil.clean() nulls out the
      logger and Benchmark uses logging, so the last stopTime() call
      requires this check to avoid a NPE.
      compiler/util/Benchmark.java
      Added PRECOMPILE and POSTCOMPILE constants.
      Added getTime() and a new version of stopTime() that allows the
      duration reset to be skipped.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Benchmark.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/ThreadLocalToolkit.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Configuration.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
