0 Replies Latest reply on Aug 15, 2008 6:38 AM by (Paul_Reilly)
    [svn] 2850: Modified encoding to use BEST_SPEED, instead of BEST_COMPRESSION, when
    Level 1
      Revision: 2850
      Author: preilly@adobe.com
      Date: 2008-08-15 07:38:34 -0700 (Fri, 15 Aug 2008)
      Log Message:
      generating debug SWF's. During active development, Flex Builder
      creates debug SWF's, so this should speed up incremental compilation
      about 10%.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: pfarland
      Code-level description of changes:
      TagEncoder.java
      Modified writeTo() to pass isDebug() as the second arg into
      SwfEncoder.writeTo().
      SwfEncoder.java
      Added compress(boolean) and writeTo(OutputStream, boolean), so
      that BEST_SPEED can be used when the arg is true. The existing
      API's compress() and writeTo(OutputStream) default to
      BEST_COMPRESSION to maintain the previous behavior.
      Also added deflate() and moved common code from compress() and
      writeTo() into this new method.
      Modified Paths:
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/SwfEncoder.java
      flex/sdk/trunk/modules/swfutils/src/java/flash/swf/TagEncoder.java
