0 Replies Latest reply on Aug 18, 2008 8:04 AM by (Corey_Lucier)
    [svn] 2869: Restoring change 2789, now that generated hostComponent properties are properly bindable.
    Level 1
      Revision: 2869
      Author: clucier@adobe.com
      Date: 2008-08-18 09:04:36 -0700 (Mon, 18 Aug 2008)
      Log Message:
      Restoring change 2789, now that generated hostComponent properties are properly bindable. With this
      change we now perform binding initialization earlier on during component construction (within the
      constructor).
      Checkin tests, mx_unit binding tests, and related Mustella tests (e.g. Button) pass.
      Reviewer: Paul R.
      Docs: No
      QA: No
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/HostComponentEvaluator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/HostComponentExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDef.vm
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
