0 Replies Latest reply on Aug 18, 2008 4:53 PM by (Jim_Murphy)
    [svn] 2876: -integrate:
    Level 1
      Revision: 2876
      Author: jimurphy@adobe.com
      Date: 2008-08-18 17:53:52 -0700 (Mon, 18 Aug 2008)
      Log Message:
      -integrate:
      -vellum build 152
      -player build 576
      -applied Gordons patch for the vellum API change
      -removed the player/[os] directories. player/10/[os] will now be the directory in which players will be integrated
      -added new variable to build.xml, player.target so that checkintests run properly and the staging for the packaging will continue to work with the structure changes
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/libs/player/10/playerglobal.swc
      flex/sdk/trunk/frameworks/libs/text_edit.swc
      flex/sdk/trunk/frameworks/libs/text_importExport.swc
      flex/sdk/trunk/frameworks/libs/text_model.swc
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextArea.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextInput.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextView.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Parser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/TextGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextFlowCompos er.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextGraphicEle ment.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/utils/TextUtil.as
      flex/sdk/trunk/in/player/10/lnx/flashplayer.tar.gz
      flex/sdk/trunk/in/player/10/lnx/install_flash_player_10_linux.tar.gz
      flex/sdk/trunk/in/player/10/lnx/libflashplayer.so.tar.gz
      flex/sdk/trunk/in/player/10/mac/Flash Player.app.zip
      flex/sdk/trunk/in/player/10/win/FlashPlayer.exe
      flex/sdk/trunk/in/player/10/win/Install Flash Player 10 ActiveX.exe
      flex/sdk/trunk/in/player/10/win/Install Flash Player 10 Plugin.exe
