0 Replies Latest reply on Aug 18, 2008 5:47 PM by (GordonSmith)
    [svn] 2878: Added an ObjectUtil.getUnqualifiedClassName() utility method for use in the className getter in four classes, which previously had copy-and-paste code.
    Level 1
      Revision: 2878
      Author: gosmith@adobe.com
      Date: 2008-08-18 18:47:49 -0700 (Mon, 18 Aug 2008)
      Log Message:
      Moved the STYLE_UNINITIALIZED constant from StyleManager to StyleProtoChain, since it indicates an uninitialized style proto chain.
      Reviewer: Jono
      Bugs: -
      QA: No
      Doc: No
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextGraphicEle ment.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/NavBar.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridItem Renderer.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectInstance.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManager.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
      flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/ObjectUtil.as
