0 Replies Latest reply on Aug 19, 2008 5:47 AM by (Paul_Reilly)
    [svn] 2890: Fixed a benchmarking problem with building the same Application or
    Level 1
      Revision: 2890
      Author: preilly@adobe.com
      Date: 2008-08-19 06:47:45 -0700 (Tue, 19 Aug 2008)
      Log Message:
      Library multiple times.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: gauravj
      Code-level description of changes:
      Modified recompile() to use the forceRecompile arg to decide if the
      PRECOMPILE start time needs to be set.
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
