0 Replies Latest reply on Aug 20, 2008 12:27 PM by (Paul_Reilly)
    [svn] 2930: Fixed up some remaining issues with precompile and postcompile
    Level 1
      Revision: 2930
      Author: preilly@adobe.com
      Date: 2008-08-20 13:27:50 -0700 (Wed, 20 Aug 2008)
      Log Message:
      benchmarking. Now we should get numbers even when
      CompilerAPI.compile() is skipped.
      tests Passed: checkintests
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: gauravj
      Code-level description of changes:
      tools/Compc.java
      tools/Fcsh.java
      tools/Mxmlc.java
      tools/oem/Application.java
      tools/oem/Library.java
      Updated benchmarking to call stopTime(Benchmark.PRECOMPILE) and
      startTime(Benchmark.POSTCOMPILE) as soon as we know
      CompilerAPI.compile() will be skipped.
      Also, added a check for
      benchmark.hasStarted(Benchmark.POSTCOMPILE) before calling
      stopTime(Benchmark.POSTCOMPILE).
      compiler/util/Benchmark.java
      Divided times Map into startTimes and duration to better handle
      the case when an exception is thrown such that startTime() is
      jumped over.
      Added hasStarted().
      Modified Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/Benchmark.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Compc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Mxmlc.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
