0 Replies Latest reply on Aug 20, 2008 2:42 PM by (Carol_Frampton)
    [svn] 2935: Finish changes related to removing webtier.dir from build. properties.
    Level 1
      Revision: 2935
      Author: cframpto@adobe.com
      Date: 2008-08-20 15:42:28 -0700 (Wed, 20 Aug 2008)
      Log Message:
      Finish changes related to removing webtier.dir from build.properties. Move readme.txt to webtier directory to simplify directory structure and make it more obvious so it is more likely to be kept current. Update readme.txt to replace references to Flex 3 with Flex 4.
      Modified Paths:
      flex/sdk/trunk/modules/webtier/bootstrap/build.xml
      flex/sdk/trunk/modules/webtier/build.properties
      flex/sdk/trunk/modules/webtier/build.xml
      flex/sdk/trunk/modules/webtier/coldfusion/build.xml
      flex/sdk/trunk/modules/webtier/servlet/build.xml
      flex/sdk/trunk/modules/webtier/taglib/build.xml
      Added Paths:
      flex/sdk/trunk/modules/webtier/readme.txt
      Removed Paths:
      flex/sdk/trunk/modules/webtier/resources/
