Revision: 3032
Author: gauravj@adobe.com
Date: 2008-08-28 15:26:30 -0700 (Thu, 28 Aug 2008)
Log Message:
Updating asdoc to generate dita based intermediate xmls. This is done using a modified version of asDocHelper.as and new set of xslt files.
Adding saxon9.jar for xslt 2.0 transformations.
Also fixing an injection from revision #2945
QA: YES
Doc:
Tests: checkintests, asdoc
Reviewed by: Pete Farland
Bugs: SDK-16644
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-16644
Modified Paths:
flex/sdk/trunk/asdoc/templates/ASDoc_Config_Base.xml
flex/sdk/trunk/asdoc/templates/asdoc.js
flex/sdk/trunk/asdoc/templates/cookies.js
flex/sdk/trunk/asdoc/templates/index-list.html
flex/sdk/trunk/asdoc/templates/index.html
flex/sdk/trunk/asdoc/templates/mxml-tags.html
flex/sdk/trunk/asdoc/templates/package-frame.html
flex/sdk/trunk/asdoc/templates/print.css
flex/sdk/trunk/asdoc/templates/style.css
flex/sdk/trunk/asdoc/templates/title-bar.html
flex/sdk/trunk/build.xml
flex/sdk/trunk/modules/compiler/asdoc/asDocHelper.as
flex/sdk/trunk/modules/compiler/build.xml
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ASDocExtension.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
Added Paths:
flex/sdk/trunk/asdoc/templates/AC_OETags.js
flex/sdk/trunk/asdoc/templates/ASDoc_terms.xml
flex/sdk/trunk/asdoc/templates/ClassHeader.xslt
flex/sdk/trunk/asdoc/templates/Classes.xslt
flex/sdk/trunk/asdoc/templates/PostProcessing.xslt
flex/sdk/trunk/asdoc/templates/all-classes.xslt
flex/sdk/trunk/asdoc/templates/all-index.xslt
flex/sdk/trunk/asdoc/templates/asdoc-util.xslt
flex/sdk/trunk/asdoc/templates/class-files.xslt
flex/sdk/trunk/asdoc/templates/class-list.xslt
flex/sdk/trunk/asdoc/templates/class-parts.xslt
flex/sdk/trunk/asdoc/templates/class-summary.xslt
flex/sdk/trunk/asdoc/templates/effectsSummary.xslt
flex/sdk/trunk/asdoc/templates/eventsGeneratedSummary.xslt
flex/sdk/trunk/asdoc/templates/fieldSummary.xslt
flex/sdk/trunk/asdoc/templates/help.js
flex/sdk/trunk/asdoc/templates/merge_dita_xml.xslt
flex/sdk/trunk/asdoc/templates/methodSummary.xslt
flex/sdk/trunk/asdoc/templates/override.css
flex/sdk/trunk/asdoc/templates/package-detail.xslt
flex/sdk/trunk/asdoc/templates/package-list.xslt
flex/sdk/trunk/asdoc/templates/package-summary.xslt
flex/sdk/trunk/asdoc/templates/package.xslt
flex/sdk/trunk/asdoc/templates/processHTML.xslt
flex/sdk/trunk/asdoc/templates/stylesSummary.xslt
flex/sdk/trunk/lib/Saxon-B-LICENSE.txt
flex/sdk/trunk/lib/Saxon-B-NOTICE.txt
flex/sdk/trunk/lib/saxon9.jar
Removed Paths:
flex/sdk/trunk/asdoc/templates/appendixes.xsl
Property Changed:
