0 Replies Latest reply on Mar 5, 2008 10:49 AM by (Jim_Murphy)
    [svn] 746: creating flex-sdk-description. xml is no longer a build machine only function, it will happen in the build .xml.
    Level 1
      Revision: 746
      Author: jimurphy@adobe.com
      Date: 2008-03-05 10:49:48 -0800 (Wed, 05 Mar 2008)
      Log Message:
      creating flex-sdk-description.xml is no longer a build machine only function, it will happen in the build.xml. There are 3 tokens in the flex-sdk-description.xml file in collateral/en_US/. The release and version vars are set in the build.properties file. build.number can be manually set in the properties in build.xml or can be passed in when building the SDK by using -Dbuild.number= , the default is "workspace"
      Modified Paths:
      flex/sdk/trunk/build.properties
      flex/sdk/trunk/build.xml
      Added Paths:
      flex/sdk/trunk/collateral/en_US/flex-sdk-description.xml
