0 Replies Latest reply on Aug 29, 2008 2:40 PM by (Jeff_Vroom)
    [svn] 3048: Always map urls through the rootURL property, even for the non-proxy case.
    Level 1
      Revision: 3048
      Author: jvroom@adobe.com
      Date: 2008-08-29 15:40:17 -0700 (Fri, 29 Aug 2008)
      Log Message:
      Always map urls through the rootURL property, even for the non-proxy case. This might
      change the behavior slightly if you set rootURL on HTTPService for the non-proxy case
      as that would have been ignored in the current code path but it seem less consistent.
      If rootURL is not set, it defaults to the swf's URL which should give the same relative
      URL semantics we get today by default when rootURL is not set.
      blazeDS checkintests pass
      Modified Paths:
      flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/http/AbstractOperation.as
