3 Replies Latest reply on Jun 7, 2006 7:12 AM by Newsgroup_User
    Calculator
    SimonMcC
      Can any one help. I'm a bit of a beginer with programming in general and even more so with Director and lingo. What I want to do is create a type of calculator where in a text box, if the user clicks on a button numbered 1 then 1 appears as the text. And when the user then presses 2 the text = 12 not 3 or for some reason when I try 151!
      I would be very greatful for the help
      Simon
        • 1. Re: Calculator
          Level 7
          Just append the new number to the member's text property.
          on mouseUp
          member("YourTextMemebersName").text =
          member("YourTextMemebersName").text & "2"
          end
          • 2. Re: Calculator
            SimonMcC Level 1
            Dave,
            Thanks for your help, but with this lingo used on an expanded calculator with 10 diget buttons will I have a problem? While 1 + 2, with your code would = the desired 12, I think 2 + 1 would also = 12 and not the desired 21
            Is there any chance you could expand your answer just a bit.
            Many many thanks
            Simon
            • 3. Re: Calculator
              Level 7
              "While 1 + 2, with your code would = the desired 12, I think 2 + 1 would
              also = 12 and not the desired 21"
              Why do you think that? You are just appending a digit to the end of the
              existing text. You can make a single behavior and attach it to each of your
              number buttons ( 0 - 9) assuming you are using Director's built in button
              control. If you are using your own custom graphics you will need to modify
              the code a little. This is just a starting point, if you want to do other
              thing like limit the number to 10 digits you will have to add that to the
              script as well.
              property spriteNum
              on mouseUp me
              member("display").text = member("display").text &
              sprite(spriteNum).member.text
              end
