0 Replies Latest reply on Sep 4, 2008 2:05 PM by (Jono_Spiro)
    [svn] 3105: SDK-15764, SDK-15765 -- Two long standing Ant task bugs.
    Level 1
      Revision: 3105
      Author: jspiro@adobe.com
      Date: 2008-09-04 15:05:39 -0700 (Thu, 04 Sep 2008)
      Log Message:
      - Ant Tasks fail when setting fork="true" and there are spaces in the path name
      - Setting fork="true" in Ant Tasks leads to warning
      The issue with spaces is that forked tasks construct a stringified commandline, since Java doesn't allow you to pass real String[] to a new process. When not forking, we can pass the original String[], which makes spaces irrelevent. So the fix uses a Commandline.toString(String[]) which is designed to wrap arguments with spaces correctly with quotes, so the commandline tokenizes correctly.
      Bugs: SDK-15764 SDK-15765
      QA: This affects ant calls for _all_ FlexTasks where fork=true. It would be great if we have tests for both fork="true" and "false" where we tested paths and arguments with and without spaces -- off the top of my head, good ones to try: +flexlib=/path/with spaces/, -define=CONFIG::foo,"bar with spaces", and any other arguments you can think of. Also very important: Test passing space arguments without quotes, with single quotes, with double quotes, with a mixture (illegal), and with a mixture escaping the inner set of quotes (not sure if this should work or not, probably a stupid case to test unless quotes are allowed in paths).
      Doc: No
      Reviewer: Pete
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-15764
      http://bugs.adobe.com/jira/browse/SDK-15765
      Modified Paths:
      flex/sdk/branches/3.0.x/modules/antTasks/src/flex/ant/FlexTask.java
