0 Replies Latest reply on Sep 5, 2008 10:40 AM by (Paul_Reilly)
    [svn] 3121: Optimized QualifiedIdentifierNode creation by not requiring a throw
    Level 1
      Revision: 3121
      Author: preilly@adobe.com
      Date: 2008-09-05 11:40:44 -0700 (Fri, 05 Sep 2008)
      Log Message:
      away IdentifierNode. This reduces overall object creation and GC
      time.
      tests Passed: checkintests, asc-tests
      Needs QA: YES
      Needs DOC: NO
      API Change: NO
      Reviewer: tierney
      Code-level description of changes:
      asc/src/java/macromedia/asc/semantics/FlowAnalyzer.java
      compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
      Modified NodeFactory.qualifiedIdentifier() calls to use the
      IdentifierNode's name and position.
      asc/src/java/macromedia/asc/parser/NodeFactory.java
      Modified identifier(String, boolean) to call identifier(String,
      boolean, int).
      Modified identifier(String, boolean, int) to check for "arguments".
      Modified qualifiedIdentifier() to take a String instead of an
      IdentifierNode.
      asc/src/java/macromedia/asc/parser/QualifiedIdentifierNode.java
      Modified constructor to take a String instead of an IdentifierNode.
      asc/src/java/macromedia/asc/parser/Parser.java
      Added parseIdentifierString() and parsePropertyIdentifierString()
      and modified parseIdentifier() and parsePropertyIdentifier() to use
      them.
      Modified qualifiedIdentifier() calls to use parseIdentifierString()
      or parsePropertyIdentifierString().
      asc/src/java/macromedia/asc/parser/VariableDefinitionNode.java
      Modified NodeFactory.qualifiedIdentifier() call to use the
      Modified Paths:
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/NodeFactory.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/QualifiedIdentifierNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/VariableDefinitionNode.java
      flex/sdk/trunk/modules/asc/src/java/macromedia/asc/semantics/FlowAnalyzer.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
