0 Replies Latest reply on Sep 5, 2008 12:52 PM by (Tom_Jordahl)
    [svn] 3125: Update for LCDS WSRP portal support.
    Level 1
      Revision: 3125
      Author: tjordahl@adobe.com
      Date: 2008-09-05 13:52:23 -0700 (Fri, 05 Sep 2008)
      Log Message:
      The code which extracts the endpoints from the services-config.xml (ServerConfig.as)
      will now check to see if WSRP_ENCODED_CHANNEL is set and use that URL instead.
      This limits these portlets to a single channel/endpoint.
      In NetConnectionChannel.as, if a wsrp-url query parameter is detected in an endpoint URL,
      extra information (such as session IDs) are appended the wsrp-url value instead of the
      original URL.
      Modified Paths:
      flex/sdk/branches/3.0.x/frameworks/projects/rpc/src/mx/messaging/channels/NetConnectionCh annel.as
      flex/sdk/branches/3.0.x/frameworks/projects/rpc/src/mx/messaging/config/ServerConfig.as
