0 Replies Latest reply on Sep 5, 2008 1:16 PM by Gaurav J
    [svn] 3127: Updating asdoc to replace the avmplus call with new set of java files.
    Gaurav J Adobe Employee
      Revision: 3127
      Author: gauravj@adobe.com
      Date: 2008-09-05 14:16:53 -0700 (Fri, 05 Sep 2008)
      Log Message:
      Removing all files related to asdochelper.
      QA: Yes, also please test on non windows platform.
      Doc:
      Tests: checkintests, asdoc
      Reviewed by: Pete Farland
      Modified Paths:
      flex/sdk/trunk/asdoc/templates/ASDoc_Config_Base.xml
      flex/sdk/trunk/asdoc/templates/asdoc-util.xslt
      flex/sdk/trunk/modules/compiler/build.xml
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
      Added Paths:
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsClass.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocHelper.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocUtil.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/QualifiedNameInfo.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/SortComparator.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/TopLevelClassesGenerator.ja va
      Removed Paths:
      flex/sdk/trunk/asdoc/templates/asDocHelper
      flex/sdk/trunk/asdoc/templates/asDocHelper.linux
      flex/sdk/trunk/modules/compiler/asdoc/
