Revision: 3149
Author: gruehle@adobe.com
Date: 2008-09-08 16:58:35 -0700 (Mon, 08 Sep 2008)
Log Message:
Fix bugs introduced by the display object sharing optimization. This checkin should fix ordering problems when dynamically adding/removing graphic elements, and ordering problems when changing graphic element properties that require a display object (rotation, alpha, filters, etc).
Bugs:
MXMLG-219: BitmapGraphic component content always rendered from 0, 0 origin.
MXMLG-220: setting visible property of Rect and Ellipse does nothing.
MXMLG-222: setting the alpha of a rectangle changes z-order when there are 3 or more rectangles
SDK-16754: Z-order incorrect when a Group is present
QA: Yes - the test files from these bugs (or something equivalent) should be added to our standard test suite
Reviewer: Deepa
Ticket Links:
http://bugs.adobe.com/jira/browse/MXMLG-219
http://bugs.adobe.com/jira/browse/MXMLG-220
http://bugs.adobe.com/jira/browse/MXMLG-222
http://bugs.adobe.com/jira/browse/SDK-16754
Modified Paths:
flex/sdk/trunk/frameworks/projects/flex4/src/flex/core/Group.as
flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/BitmapGraphic.as
flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/GraphicElement.as
