0 Replies Latest reply on Sep 14, 2008 4:11 AM by (Carol_Frampton)
    [svn] 3203: Add support for inline two-way data binding (syntax is @{expr}) .
      Revision: 3203<br />Author:   cframpto@adobe.com<br />Date:     2008-09-14 05:11:47 -0700 (Sun, 14 Sep 2008)<br /><br />Log Message:<br />-----------<br />Add support for inline two-way data binding (syntax is @{expr}).  Also add support for two-way data binding via the <mx:Binding> tag and the new property twoWay=boolean (default is false).<br /><br />Code Reviewer: Paul<br />QA: tests for this feature need to be added to the regression test suite<br />Doc: new feature which needs to be documented<br /><br />Modified Paths:<br />--------------<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/analyzer/SyntaxAnalyzer.java <br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java <br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AnonymousObjectGraph Builder.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java <br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ModelBuilder.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ServiceRequestBuilde r.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/XMLBuilder.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/XMLListBuilder.java< br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/BindingNode.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/lang/TextParser.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java<b r />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java<br />    flex/sdk/trunk/modules/compiler/src/java/flex2/compiler_en.properties
