0 Replies Latest reply on Sep 16, 2008 1:28 PM by (Ryan_Frishberg)
    [svn] 3236: Remove Window type selector from defaults.css in framework.
      Revision: 3236
      Author: rfrishbe@adobe.com
      Date: 2008-09-16 14:28:44 -0700 (Tue, 16 Sep 2008)
      Log Message:
      Remove Window type selector from defaults.css in framework. Window was the name of an old class in the framework that's not around anymore, so these styles aren't needed. This type selector definition was conflicting with the one defined in airframework/defaults.css for Window. The winner depended on how you compiled the file and the ordering of the swcs (settings in airconfig.xml affected it). This fix should mean there is no conflict and the type selector definition found in airframework/defaults.css for Window will always win.
      QE: Yes
      Doc: No
      Bugs: SDK-16769
      Reviewer: Evtim (also discussed with Gordon and Glenn)
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16769
      Modified Paths:
      flex/sdk/branches/3.0.x/frameworks/projects/framework/defaults-2.0.0.css
      flex/sdk/branches/3.0.x/frameworks/projects/framework/defaults-2.0.1.css
      flex/sdk/branches/3.0.x/frameworks/projects/framework/defaults.css
