0 Replies Latest reply on Sep 17, 2008 2:58 PM by (GordonSmith)
    [svn] 3248: Updated to TCAL build 173.
    Level 1
      Revision: 3248
      Author: gosmith@adobe.com
      Date: 2008-09-17 15:58:26 -0700 (Wed, 17 Sep 2008)
      Log Message:
      Updated to TCAL build 173. (Note: I did NOT update the players.)
      The three TCAL SWCS used by Flex 4 are now named tcal_core.swc, tcal_conversion.swc, and tcal_edit.swc.
      All TCAL APIs are now in a package named flashx.tcal. We are using flashx to indicate important APIs that are considered to extend the Flash platform but which live below application frameworks such as Flex.
      On TextFlow, a new 'displayController' property replaces the old 'container' and 'controller' properties.
      When importing, you use importToFlow() rather than importFromString() or importFromXML.
      Reviewer: N/A
      Bugs: -
      QA: No
      Doc: No
      Modified Paths:
      flex/sdk/trunk/frameworks/fxg-manifest.xml
      flex/sdk/trunk/frameworks/mxml-2009-manifest.xml
      flex/sdk/trunk/frameworks/projects/flex4/build.xml
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextArea.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextBase.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextInput.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/component/TextView.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/events/TextOperationEvent.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/Parser.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/TextGraphic.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/graphics/graphicsClasses/TextFlowCompos er.as
      flex/sdk/trunk/frameworks/projects/flex4/src/flex/utils/TextUtil.as
      Added Paths:
      flex/sdk/trunk/frameworks/libs/tcal_conversion.swc
      flex/sdk/trunk/frameworks/libs/tcal_core.swc
      flex/sdk/trunk/frameworks/libs/tcal_edit.swc
      Removed Paths:
      flex/sdk/trunk/frameworks/libs/text_edit.swc
      flex/sdk/trunk/frameworks/libs/text_importExport.swc
      flex/sdk/trunk/frameworks/libs/text_model.swc
