Revision: 3275
Author: gauravj@adobe.com
Date: 2008-09-19 15:01:57 -0700 (Fri, 19 Sep 2008)
Log Message:
Initial check in for support for asdoc comments in mxml files.
For adding comments at the class level or to properties defined inside mxml use the syntax
Other tags supported in asdoc should also work. for example
@SEE, @includeExamples etc.
QA: Yes
Doc:
Reviewed By: Paul
Tests: checkintests
Modified Paths:
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/TopLevelClassesGenerator.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationCompiler.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/MxmlCompiler.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/MxmlScanner.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/Node.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDef.vm
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/Model.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/decl/PropertyDeclaration.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/decl/UninitializedPropertyDeclaration.java
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/init/ValueInitializer.java
flex/sdk/trunk/modules/compiler/src/java/flex2/tools/ASDocConfiguration.java
Added Paths:
flex/sdk/trunk/asdoc/templates/images/AirIcon12x12.gif
flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/util/MxmlCommentUtil.java
