0 Replies Latest reply on Sep 22, 2008 11:04 AM by (Carol_Frampton)
    [svn] 3301: Modify <html-wrapper> task to use new underlying template structure.
      Revision: 3301<br />Author:   cframpto@adobe.com<br />Date:     2008-09-22 12:04:49 -0700 (Mon, 22 Sep 2008)<br /><br />Log Message:<br />-----------<br />Modify <html-wrapper> task to use new underlying template structure.  The external interface did not change.  The generated files now include swfobject.js rather than AC_OETags.js<br /><br />html template passed validation using http://validator.w3.org/check<br /><br />Doc:  The page "Using the html-wrapper task" in the Flex 3 doc does have some changes. All references to AC_OETags.js should be changed to swfobject.js.  In the example, myWrapperBuild.xml, the clean tag needs to be updated.<br /><br />Modified Paths:<br />--------------<br />    flex/sdk/trunk/modules/antTasks/src/flex/ant/HtmlWrapperTask.java<br /><br />Added Paths:<br />-----------<br />    flex/sdk/trunk/templates/swfobject/<br />    flex/sdk/trunk/templates/swfobject/history/<br />    flex/sdk/trunk/templates/swfobject/history/history.css<br />    flex/sdk/trunk/templates/swfobject/history/history.js<br />    flex/sdk/trunk/templates/swfobject/history/historyFrame.html<br />    flex/sdk/trunk/templates/swfobject/index.template.html<br />    flex/sdk/trunk/templates/swfobject/swfobject.js
