0 Replies Latest reply on Sep 23, 2008 10:55 AM by (Carol_Frampton)
    [svn] 3316: Switch html wrappers over to using swfobject.
      Revision: 3316
      Author: cframpto@adobe.com
      Date: 2008-09-23 11:55:06 -0700 (Tue, 23 Sep 2008)
      Log Message:
      Switch html wrappers over to using swfobject. There is only one copy of the template file index.template.html and swfobject.js in templates\swfobject. For now, until I9 when we get sync'ed with FlexBuilder, the build will generate each flavor of the template and deposit them in the usual directory structure, client-side-detection, express-installation, no-player-detection, and *-with-history directories, as expected by FlexBuilder. The old tokens which FlexBuilder and the html-wrapper task use to substitute values are still being used.
      QA: Steve Erat has a matrix of browsers and configurations which he has already tested. A few problems were found with browser history management which did not have anything to do with this change.
      Modified Paths:
      flex/sdk/trunk/build.xml
      flex/sdk/trunk/frameworks/build.xml
      Added Paths:
      flex/sdk/trunk/templates/build.xml
      flex/sdk/trunk/templates/swfobject/playerProductInstall.swf
      Removed Paths:
      flex/sdk/trunk/frameworks/javascript/FABridge/samples/srcview/SourceTree.html
      flex/sdk/trunk/frameworks/javascript/FABridge/samples/srcview/swfobject.js
      flex/sdk/trunk/templates/client-side-detection/AC_OETags.js
      flex/sdk/trunk/templates/client-side-detection/index.template.html
      flex/sdk/trunk/templates/client-side-detection-with-history/AC_OETags.js
      flex/sdk/trunk/templates/client-side-detection-with-history/history/
      flex/sdk/trunk/templates/client-side-detection-with-history/index.template.html
      flex/sdk/trunk/templates/express-installation/AC_OETags.js
      flex/sdk/trunk/templates/express-installation/index.template.html
      flex/sdk/trunk/templates/express-installation/playerProductInstall.swf
      flex/sdk/trunk/templates/express-installation-with-history/AC_OETags.js
      flex/sdk/trunk/templates/express-installation-with-history/history/
      flex/sdk/trunk/templates/express-installation-with-history/index.template.html
      flex/sdk/trunk/templates/express-installation-with-history/playerProductInstall.swf
      flex/sdk/trunk/templates/no-player-detection/AC_OETags.js
      flex/sdk/trunk/templates/no-player-detection/index.template.html
      flex/sdk/trunk/templates/no-player-detection-with-history/AC_OETags.js
      flex/sdk/trunk/templates/no-player-detection-with-history/history/
      flex/sdk/trunk/templates/no-player-detection-with-history/index.template.html
      Property Changed:
