0 Replies Latest reply on Sep 23, 2008 12:29 PM by Gaurav J
    [svn] 3319: Adding support for documentation of SkinStates metadata.
    Gaurav J Adobe Employee
      Revision: 3319
      Author: gauravj@adobe.com
      Date: 2008-09-23 13:29:09 -0700 (Tue, 23 Sep 2008)
      Log Message:
      Adding support for documentation of SkinStates metadata. xslt files still needs to be updated to generate html for this metadata.
      Removing some unused code from ASDocExtension
      Fix for SDK-16759 - @example tag adds 'How to use examples' link to a file that's not present
      Fix for SDK-17001 - ASDoc should add "import flash.events.Event" when it encounters the [Bindable] tag
      QA: Yes
      Doc:
      Reviewed By: Paul
      Tests: checkintests
      Ticket Links:
      http://bugs.adobe.com/jira/browse/SDK-16759
      http://bugs.adobe.com/jira/browse/SDK-17001
      Modified Paths:
      flex/sdk/trunk/asdoc/templates/class-files.xslt
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ASDocExtension.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/AsDocAPI.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/ClassTable.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/DocComment.java
      flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/asdoc/TopLevelGenerator.java
